jbskaggs
#1 Posted : Sunday, June 13, 2021 10:56:37 AM(UTC)
jbskaggs
Hi when I do an export I get it exported to fit 8.5x11 letter- I am frustrated with this as I need full size no scaling exports on dwg, dfx, svg. How can I make exports full size?
#2 Posted : Monday, June 14, 2021 12:20:42 AM(UTC)
Digital has a select pull down for mm, inches and so on. Svg is a funny one. I had loads of problems with it, different dpi settings gave me different scales. Something else they haven't done anything about.....
GARLIC on 6/14/2021(UTC), jbskaggs on 6/16/2021(UTC)
#3 Posted : Thursday, June 17, 2021 3:40:24 AM(UTC)
File> Page Layout> Scale> Scale Ratio must be 1
All your Draw views must have the scale 1. Click at the left top of a draw view for properties and change the scale to 1 and "Frame to Extents". For 1:1 Export it is better to use no draw views.
no idea what this have to do with the topic, but 2 persons thanked for this.... strange.......
Edited by user Thursday, June 17, 2021 3:45:01 AM(UTC)  | Reason: Not specified
jbskaggs on 6/18/2021(UTC)
jbskaggs
#4 Posted : Saturday, June 19, 2021 7:05:48 PM(UTC)
jbskaggs
I spent loads of time playing with this.... and even though scale is set to 1:1 and I have tried fit to scale, fit to area, etc I always get a very tiny export.
So if I create a 6" square in top view- set scale in page layout to 1:1 export in svg the resulting SVG is 3.023in in Inkscpe. Though Easel (by inventables a Cam Program) does import it at 3.023in as well.
I did sent model to sheet, frame to extents and it did the same thing.
I also tried a 12" square and it exported 3.446"
Could someone help me? Surly there is a way to fix this? On Shark 12
Edited by user Saturday, June 19, 2021 7:53:40 PM(UTC)  | Reason: updated actions
#5 Posted : Sunday, June 20, 2021 1:50:03 AM(UTC)
The SVG-Export works not properly. It seems this is using just the Screen-Scale in a similar way like the PDF-Export or the PNG-Export. But the DXF-Export should working properly.
Edited by user Sunday, June 20, 2021 1:51:26 AM(UTC)  | Reason: Not specified
jbskaggs on 6/20/2021(UTC)
jbskaggs
#6 Posted : Sunday, June 20, 2021 6:38:37 AM(UTC)
jbskaggs
Thank you so much! This worked.
