Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
When I convert this text to lines, I end up with jagged lines. How do I smooth this before cutting on the cnc?
Dyn_Metalworks attached the following image(s):
(31kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
Hello
Try using the Arcs from curve tool in the arc toolbar
So all the entities become arcs for smooth cnc cutting.
Edited by user Tuesday, November 23, 2021 10:02:02 AM(UTC)
2 users thanked jdi000 for this useful post.
Thanks: 351 times Was thanked: 255 time(s) in 168 post(s)
You made this wrong.
You need for good results:
http://www.cadkas.com/downgercad4.php http://www.cadkas.com/dxf-splines-in-arcs.php A very old Corel Draw Version i used 1999 made also good splines from Text.... But in SharkViaCAD i cant find such a Tool.
Originally Posted by: jdi000 Try using the Arcs from curve tool in the arc toolbar So all the entities become arcs for smooth cnc cutting. Jason
What when he have no curve already?
Edited by user Wednesday, November 24, 2021 12:12:58 PM(UTC)
Originally Posted by: jdi000 Hello Try using the Arcs from curve tool in the arc toolbar So all the entities become arcs for smooth cnc cutting. Regards Jason
I was able to find the Simplify Curves tool which didn't work, but not the Arcs from curves. Could you tell me where it's located? Thanks
Originally Posted by: Dyn_Metalworks I was able to find the Simplify Curves tool which didn't work, but not the Arcs from curves. Could you tell me where it's located? Thanks
Its in the Arcs-Section of the Toolbar.
(21kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
2 users thanked MPSchmied for this useful post.
Originally Posted by: MPSchmied Originally Posted by: Dyn_Metalworks I was able to find the Simplify Curves tool which didn't work, but not the Arcs from curves. Could you tell me where it's located? Thanks
Thank you for the reply, I'm using ViaCAD so it appears I don't have that tool.
Do you set the text resolution to super fine before you convert to lines?
Originally Posted by: murray Do you set the text resolution to super fine before you convert to lines?
Yes, I confirmed it was set to super fine.
Originally Posted by: Dyn_Metalworks Yes, I confirmed it was set to super fine.
Did you use the right mouse button on the Text for context-menu Resolution. The Text resolution will be always down, also when your global setup is "super fine". Convertet you the Text to curves or Lines? Use just the CAD-Kas Software is my suggestion.
Speculating, don't know if this'll make a difference, but is there a difference if you scale the text up with the resolution set super fine, convert to lines, then scale back down again?
1 user thanked murray for this useful post.
I ended up using inkscape for the text then importing the dxf into VC to finish the part. I appreciate everyone's replies.
