Gave it multiple tries, but have have failed miserably trying to rotate a user workplane. As usual the user manual is useless, so maybe someone knows the secret. I've repositioned the origin to the (x,y,z) location I want but now I want to align one of the workplane axes with the red (highlighted) line by rotating it around the x axis. Any help would be appreciated.
Im working in OSX SharkCAD Pro V11.
Edited by user Thursday, December 16, 2021 10:23:43 AM(UTC)
(2,007kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
did you already try the "C-key"? manual says: "move your cursor over a curve until LogiCursor indicates you are on, and then press the “C” key" press the C key repeatedly maybe "show grid" can help to find the right orientation
Draw a rectangle by three points, base along the red line, arbitrary height. Workplane by three points, the base and top LH corner of the rectangle.
(92kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: rokoko did you already try the "C-key"? manual says: "move your cursor over a curve until LogiCursor indicates you are on, and then press the “C” key" press the C key repeatedly maybe "show grid" can help to find the right orientation
Tried the 'c" command didn't work....
Originally Posted by: murray Draw a rectangle by three points, base along the red line, arbitrary height. Workplane by three points, the base and top LH corner of the rectangle.
Thx... That did the trick
