Albatrossflyer
#1 Posted : Thursday, December 16, 2021 10:15:00 AM(UTC)
Albatrossflyer
Gave it multiple tries, but have have failed miserably trying to rotate a user workplane. As usual the user manual is useless, so maybe someone knows the secret. I've repositioned the origin to the (x,y,z) location I want but now I want to align one of the workplane axes with the red (highlighted) line by rotating it around the x axis. Any help would be appreciated.
Im working in OSX SharkCAD Pro V11.
Edited by user Thursday, December 16, 2021 10:23:43 AM(UTC)  | Reason: Not specified
rokoko
#2 Posted : Thursday, December 16, 2021 12:34:14 PM(UTC)
rokoko
did you already try the "C-key"?
manual says: "move your cursor over a curve until LogiCursor indicates you are on, and then press the ā€œCā€ key"
press the C key repeatedly
maybe "show grid" can help to find the right orientation
murray
#3 Posted : Thursday, December 16, 2021 6:30:49 PM(UTC)
murray
Draw a rectangle by three points, base along the red line, arbitrary height. Workplane by three points, the base and top LH corner of the rectangle.
Albatrossflyer
#4 Posted : Friday, December 17, 2021 6:34:00 AM(UTC)
Albatrossflyer
Tried the 'c" command didn't work....
Albatrossflyer
#5 Posted : Friday, December 17, 2021 8:47:24 AM(UTC)
Albatrossflyer
Thx... That did the trick
Guest (10)
