Thanks: 5 times Was thanked: 9 time(s) in 8 post(s)
The Ability to group layers to turn on and off the ability to store these in the concept explorer. so you can turn on different groups for display. I'm not sure if you can do this any other way?
1 user thanked thefro for this useful post.
Was thanked: 44 time(s) in 41 post(s)
You will need to do sublayers so when you hit blank layer all sublayers will darken or turn off.
FX 7-10 Pro12-1592
Mac 11.6.2
2x2.8GHz Quad Xeon
32GB
Radeon HD7970 3GB
I was thinking of making a selection of layers then storing them giving them a name, so you could create many such selections and naming them so you could go back later and display those groups by selecting the name of the group you had created. like you can show or hide all but controlling groups of layers. I hope this makes sense now Brian
Sounds like sublayers to me. The layer is equivalent to the group and those groups will have sublayers, which is basically just layers, or children, under the parent.
FX 7-10 Pro12-1592
Mac 11.6.2
2x2.8GHz Quad Xeon
32GB
Radeon HD7970 3GB
I was thinking or turning on layers and som things in sub layers and being able to set that and store them save them so later you can select those switching them on saving you time going in and turning them on in another session. if I haven't put this over I give up
Originally Posted by: thefro I was thinking or turning on layers and somethings in sub layers and being able to set that and store them save them so later you can select those switching them on saving you time going in and turning them on in another session. if I haven't put this over I give up
Unfortunately, there's no way to move sublayers between layers (groups). You would have to duplicate the sublayer which becomes a layer which you can then flatten and change all the components flattened to any layer or sublayer. Alternatively, you can select all objects in that layer or sublayer and move them to another layer or sublayer. Theres a command to select all objects in that layer but I think they have to be all visible.
You need to establishh your group and its children first so that you can just toggle to show all under the parent thus switching them on. Moving components around is just another way which takes time.
Edited by user Thursday, January 20, 2022 10:07:50 AM(UTC)
| Reason: typo
FX 7-10 Pro12-1592
Mac 11.6.2
2x2.8GHz Quad Xeon
32GB
Radeon HD7970 3GB
all im asking for is the ability to show a layer and perhaps some sub layers turn on the little eye so it displays storing that like a snapshot of things turned on stop that then set up another view showing other layers switched on and maybe do others so layer you can show one of the groups you have recorded. I think in not getting my thoughts over
