geewee
#1 Posted : Thursday, July 28, 2022 7:01:42 AM(UTC)
geewee
Hi
When making a model to sheet, how can I add another viewport from another part in the model? Is it possible to "re-select" the part of the model from an existing viewport frame?
Im using viacad V11 2d/3d
Edit:
I actually found the "new draw view" option to create a second view in a sheet after using "model to sheet" I learned that you can copy paste selections from the model into the viewport. However not with polygons, lines and circles do but not polygons.
Polygons do go into the view if i do a new model to sheet.
has anyone an idea how I can add also polygons to a new view?
Everthing i do is in 2D.
regards.
Edited by user Thursday, July 28, 2022 10:52:42 AM(UTC)  | Reason: Not specified
#2 Posted : Saturday, July 30, 2022 8:45:52 AM(UTC)
Was thanked: 255 time(s) in 168 post(s)
I guess you have to change the polygons to single lines.
Edited by user Saturday, July 30, 2022 8:46:46 AM(UTC)  | Reason: Not specified
