David Allan Cowan
#1 Posted : Thursday, January 28, 2021 6:38:43 PM(UTC)
David Allan Cowan
Been using basic 3d/2d for many years. Interchangeably importing/exporting step files. This is important because it is the format of choice for manufacturers. My computer went down and I lost the disk and so I had no choice but to 'upgrade' to the latest version. I'm really quite annoyed by this. On the upgrade I lost the STEP file export, if I am reading things correctly, and so I am now in a bit of a mess. I'm not familiar with other file formats, so is there a way of exporting/ importing one of the other formats and converting to STEP perhaps.
I'm really quite desperate any suggestions welcome.
David
Art Smith
#2 Posted : Thursday, January 28, 2021 8:36:31 PM(UTC)
Art Smith
what program and version number are you currently using? PC or mac??
Art
artesmith@earthlink.net
David Allan Cowan
#3 Posted : Friday, January 29, 2021 4:30:19 AM(UTC)
David Allan Cowan
Version 12.0 Just bought it. The Step import/export should be there according to the user guide. It is not a premium feature. And I am using a PC. Thanks. Oh and I am using the ViaCAD 2d/3D.
Edited by user Friday, January 29, 2021 4:32:16 AM(UTC)  | Reason: Forgot something first time
David Allan Cowan
#4 Posted : Friday, January 29, 2021 4:31:10 AM(UTC)
David Allan Cowan
rockyroad_us
#5 Posted : Friday, January 29, 2021 8:06:02 AM(UTC)
rockyroad_us
Even if you lost the disk, you should be able to download a demo version of a previous version and should work for a month or 15 days until you manage to get that old version registered. It is good practice to backup your hard drive once in a while.
Good luck exporting .stp from a PC. That feature should be there as export.
murray
#6 Posted : Friday, January 29, 2021 3:48:10 PM(UTC)
murray
It's not present in 2D/3D because ACIS isn't in VC non-Pro anymore, so no NURBS support, but they haven't been explicit, I'd say they've been misleading about it. No .stp, no .igs.
flori
#7 Posted : Wednesday, January 11, 2023 3:56:45 AM(UTC)
flori
i am new to VIACAD since my boss made me use it.
I having a lot of Problems importing STEP files.
They won't work (Missing integer is displayed) or if they work they come in in wrong Units. Means mm is change into Inch so the Model becomes much bigger. Which is kind of a Problem mostly for standard Parts.
I already send a report to support but by now the only solution was a trial of Viacad 12, that worked but boss won't pay.
I am Using VIACAD v10.0.4 Pro Build 1359
On a Win 10 Pro Xenon 3,5GHZ 64bit System.
Thanks for any answer
KQB2H12-02S.STEP (71kb) downloaded 4 time(s).
#8 Posted : Wednesday, January 11, 2023 2:46:44 PM(UTC)
The latest Build of V. 10 is 1369. SharkVia export the steps only in imperial, but also metric steps was imported in the right way. I cant repeat your problem.
Edited by user Wednesday, January 11, 2023 4:25:25 PM(UTC)  | Reason: Not specified
flori on 1/13/2023(UTC)
flori
#9 Posted : Thursday, January 12, 2023 7:22:22 AM(UTC)
flori
hi,
thanks for the answer.
when i check for updates it says: "You are running the most current build. No update is necessary."
see screenshot. I am also in contact with support but until now there is no solution.
Boss has same version it woorks tried to uninstall an intall several times.
Thanks again
flori attached the following image(s):
most current build.jpg (55kb) downloaded 2 time(s).
#10 Posted : Thursday, January 12, 2023 10:15:07 AM(UTC)
Uninstall is not needed. Tha latest build is not provided with the auto updater. This WIP Builds was provided here in the forums over the masterviacad-platform. I have no idea why the best Builds not available with the autoupdater. I guess they will force you in this way to do a upgrade.
Edited by user Thursday, January 12, 2023 11:08:26 AM(UTC)  | Reason: Not specified
#11 Posted : Thursday, January 12, 2023 2:35:59 PM(UTC)
WIP builds accessed through the masterviacad site stand for work in progress builds.
WIP builds do not go through the rigorous testing by QA and include the note below. The builds accessed through the updater are fully tested by QA.
If you use a WIP build, I recommend you append a version number to current build as backup before you install the WIP.
Having said that, I'm not aware of any major issues with the V12 WIP builds.
Also, the only issues I'm aware of with the STEP translator are typically related to tolerances of trimmed surfaces which can be verified using Verify Check Object tool. The STEP provided above checks out fine. If you do have tolerance issues, I would then try SAT/SAB after STEP, especially if coming from SolidWorks. SolidWorks includes ACIS components as both Spatial and SolidWorks fall under the Dassault umbrella and share certain technology.
WIP Notice
The WIP builds are a work in progress version. As such, this product may crash, lockup, or corrupt files. Use at your own risk.
Edited by user Thursday, January 12, 2023 2:45:29 PM(UTC)  | Reason: Not specified
thanks 3 users thanked Tim Olson for this useful post.
creativecad on 1/12/2023(UTC), flori on 1/13/2023(UTC), specktech on 2/3/2023(UTC)
flori
#12 Posted : Friday, January 13, 2023 4:10:33 AM(UTC)
flori
Thanks for your answers,
Todd from support gave me build 1370 today that seems to work fine.
thanks for helping again.
Edit: Yesterday i overwrote the EXE-folder under Punch with the EXE-folder from my boss. That helped! instead of 2d/3D build 1370 Eng, i've got now Pro german build 1359. Which is last in German.
Probably there where some missing .dll files.
Edited by user Wednesday, February 1, 2023 6:18:53 AM(UTC)  | Reason: Not specified
thanks 1 user thanked flori for this useful post.
floW
#13 Posted : Thursday, January 22, 2026 7:36:41 AM(UTC)
floW
Dear all,
can anyone help me and convert a *.pob file to a *.step file or to another common format?
I downloaded the CAD file from the manufacturer of my oven, but it's in pob format and I have no software to open files like this.
I would be more than happy if anyone drops me a line via pm or mail! Unfortunately the file size is a bit too large to attach it here directly.
Best regards
Florian
Edited by user Thursday, January 22, 2026 7:40:33 AM(UTC)  | Reason: Not specified
mitchb
#14 Posted : Friday, January 23, 2026 8:57:50 PM(UTC)
mitchb
Was thanked: 76 time(s) in 38 post(s)
Try convert pob I have not used this service so I can't vouch for them, but give it a try and let us know.
Guest (7)
