#1 Posted : Friday, January 27, 2023 5:32:50 AM(UTC)
Hello,
This is a very frequent and long standing issue for me :
- Create a few blocks (any)
- Do a modification on one of the block (blend an edge)
- Boolean add this modified block with another, selecting the other block first (it changes the position in history.
- Boolean add or subtract some other blocks (not sure it is mandatory)
- Go to the feature tree (history) and remove feature blend...
---> the first block comes back and the history of the complete solid is broken
Bug history.sfx (65kb) downloaded 4 time(s).
thanks 2 users thanked jlm for this useful post.
damhave on 1/27/2023(UTC), specktech on 1/31/2023(UTC)
NWIR
#2 Posted : Friday, January 27, 2023 10:44:02 AM(UTC)
NWIR
This is longstanding behavior. See this I posted on 8 years ago: Cut/Paste/Duplicate and Object History - Keeping an editable history when duplicating objects
http://forum.punchcad.co...sts&t=7365#post27493
This may not be the same thing, but in think it is at least related.
The best I can explain it is at some point in editing an object, the ACIS kernel hides the internals away as an opaque ACIS object.
thanks 1 user thanked NWIR for this useful post.
#3 Posted : Saturday, January 28, 2023 9:58:57 AM(UTC)
Originally Posted by: jlm Go to Quoted Post
---> ...the history of the complete solid is broken
When the solid has been used in a MTS drawing before being broken, it is a complete disaster.
This is why I always do MTS drawings on a separate file ("saved as" from my 3D construction)
As it is fully repeatable, I hope it can be solved soon...
GARLIC on 1/28/2023(UTC), specktech on 1/31/2023(UTC)
#4 Posted : Sunday, January 29, 2023 5:19:57 PM(UTC)
I can repeat your steps and looking into a fix. Related to using a boolean feature.
thanks 3 users thanked Tim Olson for this useful post.
damhave on 1/30/2023(UTC), jlm on 1/30/2023(UTC), specktech on 1/31/2023(UTC)
#5 Posted : Sunday, February 26, 2023 4:22:43 AM(UTC)
Repeats in b1620 even in a very simple configuration :
Make 2 blocks
filet one edge of one block
Boolean add the 2 blocks starting with clicking the non-filleted
Remove feature fillet
---> history broken
thanks 3 users thanked jlm for this useful post.
MPSchmied on 2/26/2023(UTC), GARLIC on 2/26/2023(UTC), damhave on 2/26/2023(UTC)
