12 years now, and I am still not seeing a layer system that doesn't feel like some cartel dropped an anvil on Shark/ViaCAD. It feels like "If you intro that featue, we'll NUKE your company. Don't go there, and don't acknowledge even the request". The duplicate layer is NOT sufficient. Exporting out and into is NOT sufficient, as it creates a needless upper layer with each export/reimport. The team surely has the technical chops to do it. It seems like it's an artificial limitation that its not a featue. I've lost track of how many files I've ditched and restarted because its not possible to within a file or between files drag content with or without associativity to or from layers. It's just pointers and addresses in a database, no? If it's not in V14, I will skip until it's a feature. Other CAD apps allow it, and I don't want to needlessly export to other apps just to reorganize many hundreds of layers, only to destroy any layer object associativity or properties. I'll even be ok with exporting the layer names to a CSV with layer IDS, sorting it out myself in a spreadsheet, and when do e pointing Shark at the new reorg file and waiting, even if it's 8 hours, for Shark to do the rest. But, the spreadsheet interface HAS to be vendor agnostic. No deliberate focusing on only MS Excel. Go CSV, tab-delimited, or the like. Be kind. It feels incredibly heartbreaking, stressful, and like a 500-lb wrecking ball to the chest that seemingly such a basic feature has not been introduced and matured.
2 users thanked ZeroLengthCurve for this useful post.
Thanks: 73 times Was thanked: 84 time(s) in 45 post(s)
I like many of the layer features we have: sublayers, selecting everything in a layer, lock/unlock all, expand all/collapse all. But I agree that it would be nice to copy, duplicate, or move a layer with all its sublayers to different hierarchies of layers. I also think it would be great to make all of the sheets sublayers under 1 layer and maybe all model layers sublayers under 1 layer. This would allow us to lock or turn off all of the sheets at once while working on the model or turn off all model layers while working on the sheets. I have had several times where I accidentally picked up my sheets when I was working on the model. Also, it would be nice to have the ability to show the current work layer with the concept explorer collapsed or closed. Maybe showing the current layer in the inspector as well would be enough. Also, my current build does do saved views which work until I close the program, but after I close the program and reopen it the next day, my views are zoomed way out which is really annoying to have to recreate them every day. I especially would like a saved view that works of my sheets that I can click on to go straight to the print sheets. Thankfully, the main views usually go straight back to where I last was which helps a lot. However, we need a previous view command. So if I look at something in 3d, then click on the sheet view, I could click on previous view to jump straight back to my previous 3d view.
ViaCad 10 Pro ViaCad 9 Windows 10
3 users thanked creativecad for this useful post.
I agree importing and exporting can be a pain with the layers. I think if we had the ability to move layers up and down the hierarchy would help with this.
Originally Posted by: creativecad I agree importing and exporting can be a pain with the layers. I think if we had the ability to move layers up and down the hierarchy would help with this.
I agree !
The file I'm currently working on has 37 layers, each layer has at least 3 sub-layers.
Very often I get broken links when I move parts from one layer to another, or even crashes when I delete empty layers.
My thought :
with a
more robust feature tree ,
better layer management and
better MTS interface , SFX would be the best creation tool !
No need new functions...
5 users thanked jlm for this useful post.
