sweboss
#1 Posted : Sunday, February 26, 2023 1:07:07 AM(UTC)
sweboss
I try to figure out how to use the Insert Group Tool in the Architectural section. As I understand from the manual I should make a group containing for example a wall with different attachments, such as windows and doors. Then choose the tool, pick the wall where I want to place the group, pick th group and the point on the position of the wall where I want to place the group. This is exactly what I try to do, but as you can see in the attached screen recording, the result is quite unexpected.
I'm running ver 14 Deluxe on a MacBook Pro 15-2018 with Ventura 13.2.1
Insert Group.mp4 (3,396kb) downloaded 5 time(s).
