Kartoffel
#1 Posted : Wednesday, March 1, 2023 7:11:23 AM(UTC)
Kartoffel
I have some gears from a toy rc-car gearbox, I want to rebuild.
I thought this would be an easy task with the new gear-tool in the powerpack of sharkcad 12.
But I don't get a proper result. The gear, the tool is creating, is way too big...
Edited by user Wednesday, March 1, 2023 7:14:25 AM(UTC)  | Reason: Not specified
Kartoffel attached the following image(s):
#2 Posted : Wednesday, March 1, 2023 7:42:43 AM(UTC)
Was thanked: 308 time(s) in 207 post(s)
If I remember rightly the input needs to be in inches. Don't know why but when I tried this out years ago it was the issue then
#3 Posted : Wednesday, March 1, 2023 8:19:53 AM(UTC)
Was thanked: 151 time(s) in 96 post(s)
Hello Kartoffel,
When the gear tool was introduced there was a confusion in units : mm were changed into inches.
It makes everything bigger with factor 25.4.
I thought this had been solved...
Edited by user Wednesday, March 1, 2023 8:20:52 AM(UTC)  | Reason: Not specified
GARLIC on 3/1/2023(UTC)
Kartoffel
#4 Posted : Wednesday, March 1, 2023 8:34:14 AM(UTC)
Kartoffel
Thanks for the hint.
With the module in inches and the radius in mm it works. Stupid!
But in the end, the tooth-shape is totally different, so I will manually design one tooth and then go on with the polar duplicate ...
Markus
thanks 1 user thanked Kartoffel for this useful post.
damhave on 3/1/2023(UTC)
#5 Posted : Wednesday, March 1, 2023 9:18:08 AM(UTC)
Markus
In the past I used a web site to design gears, it was free and exporting DXF to shark.
I think it was that one :
Gear generator tool
Edited by user Wednesday, March 1, 2023 9:23:22 AM(UTC)  | Reason: Not specified
MaiFy on 3/1/2023(UTC)
Kartoffel
#6 Posted : Thursday, March 2, 2023 5:25:53 AM(UTC)
Kartoffel
I used this program now: http://forestmoon.com/Software/GearDXF/
But in the end, it is very dissapointing for me, that the "gear-tool" has only basic parameters + the problem with the units...
Markus
#7 Posted : Thursday, March 2, 2023 2:50:41 PM(UTC)
The unit issues should have been fixed in V14.
#8 Posted : Friday, March 3, 2023 5:47:02 AM(UTC)
Was thanked: 132 time(s) in 102 post(s)
How about switching completely to mm?
This problem in this thread is a problem with relative and absolute values.
I have such a problem found i the sheet metal tool of MegaCAD. Wen i load there the imperial Models from Shark, i need in the Sheet Metal tool then values in Inches.
Switch the native system please to Millimeter because i have no possibility to change a 3D-Modal from Imperial in Millimeter. It stay everytime in Imperial, because the programs work with relative values, it doesn't matter until they work with absolute values.
GARLIC on 3/3/2023(UTC)
relaxibus
#9 Posted : Friday, March 3, 2023 7:54:42 AM(UTC)
relaxibus
Was thanked: 38 time(s) in 24 post(s)
Yeah, I had the same issue using the tool. Pitch was in inch on a metrical Shark.
Another online tool cool to explore may be to add some features in the Shark Gear Tool? https://drivetrainhub.com/gears/
thanks 1 user thanked relaxibus for this useful post.
