I am new to this forum, but already using sharkcad since 2018.
There is an issue with sharkcad v14.0.0 Build(1616)
File Error This file is damaged! Cannot read into appllication File position: 15297895 File size: 23563049 Filename: xxx.sfx (changed because of customer name) There are more files with these errors, what can cause this? Is there a workaround for this problem?
Regards,
Mark
Edited by user Thursday, March 9, 2023 7:32:27 AM(UTC)
sharkcad v14 , Macbook Pro M1, MacOS 13.0.1, Ventura
Mark Can you try 1620 and let me know if the file reads in. If not, can you send me the file private. Tim
Thanks: 48 times Was thanked: 85 time(s) in 57 post(s)
Hi Tim,
I just got this on macOS too. It was caused by me forcing a shutdown of a few open applications, as I lost my mouse cursor.
I just went to open the file from the dropdown menu aka #1 and got this error, the same as the OP.
Obviously SharkCAD (1620) had unsaved changes, and I think the forced shutdown caused the problem.
Mike
(43kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Tim Olson Mark Can you try 1620 and let me know if the file reads in. If not, can you send me the file private. Tim
Hi Tim,
Thanks for your support.
Is there a download link?
When clicking on help -> version, You are running the most current build. No update is necessary
Help -> Upgrade, the complete text is not visible, but then i need to Buy a new version?
regards,
Mark
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
Originally Posted by: MarkPen but then i need to Buy a new version?
No. You have already v.14. All v. 14 Updates get you for free.
Use the WIP-Builds in the Beta-Forum and not the Update-Function of the Program.
version 1620, same problem. Just send the files to Tim. regards, Mark
Mark, I was able correct for the larger of the two files you provided in 1621. Tim
Thanks Tim, build 1621 opened my 85Mb file successfully, that was reporting as damaged before in 1620. :) Mike
Originally Posted by: Tim Olson Mark, I was able correct for the larger of the two files you provided in 1621. Tim
Hi Tim,
Okay, i will download that version. Thanks!
And the other file? What happend there.
Regards,
Mark
