#1 Posted : Tuesday, March 28, 2023 7:47:15 AM(UTC)
This one brings back memories from when I worked Lockheed/General Dynamics advanced design team...
Steps I used to create this quick setup rendering...
1. F-16C model downloaded from grabcad.
2. Changed pen color of fuselage to grey
3. Deep select the canopy surfaces and set material type to glass
4. Enabled ground shadows, denoiser, and use default HDR from photo render settings dialog
5. Googled an airport runway from Microsoft Flight Simulator and set as file background
6. Zoomed, panned, rotated view until wheels looked appropriate to runway background image
7. Rendered with halt time 10000
This was done with SharkCAD 14 build 1623. It needs some decals/tail number, color tweaks....to be done later.
Edited by user Tuesday, March 28, 2023 8:47:04 AM(UTC)  | Reason: Not specified
thanks 4 users thanked Tim Olson for this useful post.
jlm on 3/28/2023(UTC), damhave on 3/28/2023(UTC), GARLIC on 3/28/2023(UTC), specktech on 4/10/2023(UTC)
#2 Posted : Wednesday, March 29, 2023 7:23:22 AM(UTC)
Was thanked: 132 time(s) in 102 post(s)
Such images should be rendered in jpg. Microsoft Flight Simulator as background?
Nice that now glass can be rendered. This is new i guess. My Shark versions can't do glass.
I will watch in grabcad for this model :)
#3 Posted : Wednesday, March 29, 2023 8:51:19 AM(UTC)
Further clarification, the background came from the MFS forum...
The new rendering engine handles glass and metals very nicely.
thanks 3 users thanked Tim Olson for this useful post.
GARLIC on 3/29/2023(UTC), MPSchmied on 3/29/2023(UTC), specktech on 4/10/2023(UTC)
