2 Pages12>
la mouche
#1 Posted : Tuesday, May 19, 2009 2:29:29 AM(UTC)
la mouche
Hello Tim,
http://forum.punchcad.com/showthread.php?t=1970
always the same problem in version 5.5
:confused::mad::mad:
I'm discouraged
Regards.
Antoine
ttrw
#2 Posted : Tuesday, May 19, 2009 3:58:05 AM(UTC)
ttrw
http://forum.punchcad.com/showthread.php?t=1934
Was this not fixed as promised then? :eek:
la mouche
#3 Posted : Tuesday, May 19, 2009 5:24:32 AM(UTC)
la mouche
..no :o
with SharkFX 833
See the attach files please.
Antoine
Image 1.jpg (23kb) downloaded 5 time(s).
Image 2.jpg (24kb) downloaded 5 time(s).
#4 Posted : Saturday, May 30, 2009 6:55:11 PM(UTC)
Antoine,
Can you post the shark file and I can check on this end?
la mouche
#5 Posted : Wednesday, June 3, 2009 2:22:53 AM(UTC)
la mouche
hello Tim.
The file
guide skin solid.sfx.zip (223kb) downloaded 5 time(s).
#6 Posted : Wednesday, June 3, 2009 1:05:29 PM(UTC)
Try selecting the skin sections where the first section starts at the beginning of the rail. Use the Verify : Direction to show the start of the rail.
http://www.csi-concepts.com/Demo/videos/SkinGuide.mov
la mouche
#7 Posted : Tuesday, June 9, 2009 1:51:12 AM(UTC)
la mouche
hello Tim,
Thanks for your reply.
mais... oohh nooonnn!!!
c'est si simple??!!:confused:
I think it would be to secure the success of this function, no?
Antoine
Yeaaahhhhh very very happy :p:p:p
unique
#8 Posted : Tuesday, June 9, 2009 3:58:14 AM(UTC)
unique
Tim,
I havent tried doing this in VC but what would happen if the user could not define the section exactly where the start of the curve happened to be. Can the user easily move the seam point on the profile curve or what would they need to do please, if anything ?
la mouche
#9 Posted : Tuesday, June 9, 2009 6:08:27 AM(UTC)
la mouche
hello
the profile is not similar the sections.
Thanks.
Antoine
Image 3.jpg (496kb) downloaded 5 time(s).
solid skin.sfx (1,072kb) downloaded 5 time(s).
Image 2.jpg (79kb) downloaded 5 time(s).
Image 5.jpg (330kb) downloaded 5 time(s).
Steve.M
#10 Posted : Tuesday, June 9, 2009 2:39:42 PM(UTC)
Steve.M
Tim,
I dont have the guide skin solid tool to try, but the guide skin surface for this type of closed shape is a disaster currently.
- Steve
Steve.M
#11 Posted : Wednesday, June 10, 2009 5:21:16 AM(UTC)
Steve.M
I have just attempted to guide skin these cross sections.
First. Are the sfx files not compatible with VC pro, because VC pro became unresponsive. I gave it 10 minutes, but had to kill the process (I did try twice with same result).
I used the cross sections after converting them to iges. The first pic is the result from Guide skin surface from VC pro, which is certainly incorrect and needs to be thrown away. The second pic is the same cross sections/guide used in Rhino, giving results as expected.
Tim. You really need to sort this out.
- Steve
zumer
#12 Posted : Wednesday, June 10, 2009 6:24:53 AM(UTC)
zumer
FWIW, the branched solid tool is well behaved for this shape.
guide skin solid.vc3 (422kb) downloaded 5 time(s).
la mouche
#13 Posted : Wednesday, June 10, 2009 6:52:49 AM(UTC)
la mouche
hello,
Thanks for yor reply.
But the branched solid tool not work with guide constraint.
see please the attach file.
The question is: why the faces internal surfaces is not vertical?
Same the splendid exemple with Rhino, see the file from Steve: 02.jpg
Antoine
shell 3.jpg (426kb) downloaded 5 time(s).
Steve.M
#14 Posted : Wednesday, June 10, 2009 7:01:09 AM(UTC)
Steve.M
Interesting. The result does require separating and then stitching back before any shelling can be made, but the shape is reliant on what is produced and cannot be controlled via guides.
- Steve
Steve.M
#15 Posted : Wednesday, June 10, 2009 8:07:12 AM(UTC)
Steve.M
Well, I had a look at adding another guide, but with the same disastrous result.
I did add splines and then joined these, which gave further problem. After trying various I had the sections on 2 guides (joined splines),pic04. I decided to split the bottom spline to try and get the start position the same, but the spline endpoint just flew out into space when segmented, pic05.
I must say this is the buggiest CAD system I have ever used.
la mouche
#16 Posted : Wednesday, June 10, 2009 8:31:58 AM(UTC)
la mouche
same result with Cobalt.
Antoine
ttrw
#17 Posted : Wednesday, June 10, 2009 9:02:47 AM(UTC)
ttrw
Poor old Tim! LOL! :D:D
I dunno though, you could try the aptly named "BRL-CAD", which is completely command-line based. However, I think the developer has been consumed by giant flesh-knawing ants :eek:
zumer
#18 Posted : Wednesday, June 10, 2009 9:42:48 AM(UTC)
zumer
Most of the US military's hardware that was designed before the mid '90s was designed with BRL Cad. Very tough, but hard to use without training. Up until about five years ago, it was only available to US nationals, because theirs was the tax money that developed it. When the tax money dried up, so did the company.
Steve.M
#19 Posted : Wednesday, June 10, 2009 9:57:02 AM(UTC)
Steve.M
I think I did look at that at one time. If I remember correctly the help file put forward building a model as a "Mission" .
We are already on a mission here, trying to get Tim to sort out VC shark.
- Steve
ttrw
#20 Posted : Wednesday, June 10, 2009 11:17:52 AM(UTC)
ttrw
I
Quite right. This buggy situation is quite unacceptable.
Guest (10)
2 Pages12>
