#1 Posted : Sunday, April 30, 2023 11:32:17 PM(UTC)
WIP Build 1628 is now ready for testing. Download links from:
http://www.masterviacad.com/beta/beta.php
Change Log for 1628
1. Corrected instance of file corruption when reading in decals from V12
2. Corrected view clipping instance in ortho and perspective views
3. Corrected unit conversion issue with camera focal length
4. Added a prompt message when calculating mass properties without material assignments
Jean-Francois Jacques
#2 Posted : Monday, May 1, 2023 9:45:12 AM(UTC)
Canada
WARNING -
Build 1628 doesn't work !!!
I can use tools ...but nothing appears on my display !!
Screen Recording 2023-05-01 at 11.42.01.mov (968kb) downloaded 13 time(s).
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
thanks 1 user thanked Jean-Francois Jacques for this useful post.
GARLIC on 5/1/2023(UTC)
24c
#3 Posted : Monday, May 1, 2023 10:41:05 AM(UTC)
24c
Hi Jean-Francois,
I'm using build 1628 from this morning, no problems for me on macOS Ventura 13.3.1 and using MateView as Main Display attached to MacBook M1 Max via USB-C.
Have you looked at your SharkCAD Pro settings, do you usually have a blue screen background?, have you tried defaults?, quitting, re-opening SharkCAD and/or rebooting your computer.
I had no problems, if anything Skin Solid tool was behaving better than 1627 WIP.
Mike
Edited by user Monday, May 1, 2023 10:43:26 AM(UTC)  | Reason: Not specified
macOS Tahoe-v17 beta b1908
#4 Posted : Monday, May 1, 2023 12:24:06 PM(UTC)
Canada
I found it !
With Intel chip
Nothing on my screen with the Orthogonal View, the display appear if I click on the Perspective View!!
Edited by user Monday, May 1, 2023 12:29:23 PM(UTC)  | Reason: Not specified
Display.mov (1,893kb) downloaded 7 time(s).
#5 Posted : Monday, May 1, 2023 12:57:22 PM(UTC)
Do you have View :Show Axis turned on or off?
#6 Posted : Monday, May 1, 2023 1:05:42 PM(UTC)
Canada
I tried both ..with and without!
#7 Posted : Monday, May 1, 2023 1:19:34 PM(UTC)
Canada
Please, look the gripper in Perspective view !!
Edited by user Monday, May 1, 2023 1:20:11 PM(UTC)  | Reason: Not specified
Jean-Francois Jacques attached the following image(s):
Screenshot 2023-05-01 at 15.18.28.png (102kb) downloaded 2 time(s).
#8 Posted : Monday, May 1, 2023 2:49:00 PM(UTC)
The perspective no longer works with version 1628. I reinstalled version 1627 and it works again.
Can you provide a zip file instead of an exe file for installing the software? Installing the exe file takes too much time. I use Beyond Compare for installing zip files, which is much faster.
#9 Posted : Monday, May 1, 2023 3:32:11 PM(UTC)
I switched the auto responder back to 1627 until I figure out what's different.
So hold off downloading 1628 for now..
24c
#10 Posted : Monday, May 1, 2023 4:15:09 PM(UTC)
24c
...So hold off downloading 1628 for now..
Oddly I'm unable to replicate the Orthogonal View & other issues reported, even if I open a new drawing in 1628.
Unable to test Windows as haven't downloaded that version of SharkCAD yet.
Mike
#11 Posted : Tuesday, May 2, 2023 10:30:29 AM(UTC)
I opened a larger file today in v. 1627 and tested the perspective; however, the perspective did not work properly with this file. I remember that I had already changed the "Eye Point" in this file. How can I reset the "View Properties" to the default settings? Perhaps this structure with dimensions of 6x6x4m is too large for the perspective? Additionally, I tried opening a larger DXF file, which can be opened quickly in v.9 Build 1162 and only causes a slight zoom lag. However, I could not open the file at all in Build 1627, and this attempt resulted in an endless loop.
Edit:20468 objects are too much. I was able to disable the layer with the many objects and have to say that nothing is better with the DXF import. Dashed lines are displayed as continuous lines. As soon as I reactivate the layer with the 20468 objects, the endless loop occurs again.
Edited by user Tuesday, May 2, 2023 11:05:11 AM(UTC)  | Reason: Not specified
