Thanks: 8 times Was thanked: 16 time(s) in 13 post(s)
Is the Help -> Current Version function supposed to work? Ever since I started using Via/Shark (several years ago) I've never had it tell me that a new version is available. I'm currently running a WIP build (1624 on Mac) if that makes a difference, although I haven't seen any updates from mainline builds either.
1 user thanked lightbulbjim for this useful post.
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
Originally Posted by: lightbulbjim Is the Help -> Current Version function supposed to work?
With this feature, you will not receive the work-in-progress (WIP) builds, as they may not be stable enough due to insufficient testing.
Originally Posted by: MPSchmied Originally Posted by: lightbulbjim Is the Help -> Current Version function supposed to work?
Understood, but I've never seen it report
any updated version available, not even stable releases. Does it work for anybody else?
Thanks: 263 times Was thanked: 82 time(s) in 48 post(s)
Same here... I have never seen any updates via the program menu. But at least I find that the WIP builds are stable and normally works good (at least on Windows). Currently I run SharkCad Pro build 1628 (WIP) on windows 10 and it runs excellent :-)
Edited by user Monday, May 8, 2023 5:24:31 AM(UTC)
| Reason: added (WIP)
BR Danny Win10 Pro, SharkCAD Pro v14(1653) v15(1722) Dell XPS 15 Sonoma 14.7.1 SharkCAD v14 Pro(1653), MacBook Pro 14 2023,M3
