Forum Error
Startup Error: Unable to connect to the Database. Exception Message: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server) (53)
Please contact the administrator if this message persists.
Note: If you are the administrator, and need help with this problem, please Turn off CustomErrors in your web.config.
Try Again
