24c
#1 Posted : Tuesday, August 29, 2023 1:22:48 PM(UTC)
24c
Was thanked: 50 time(s) in 37 post(s)
Not sure if this is possible, but I'm trying to draw a bracket and model it in 3D.
I don't seem to be able to split the folded area, as the whole surface is folded, so in the end I had to create another folded part, rotate it and join the two solids.
Mike
Edited by user Tuesday, August 29, 2023 1:25:29 PM(UTC)  | Reason: Typo
Screenshot 2023-08-29 at 20.13.24.png (532kb) downloaded 21 time(s).
L. Banasky
#2 Posted : Tuesday, August 29, 2023 5:08:40 PM(UTC)
L. Banasky
Was thanked: 143 time(s) in 101 post(s)
I did a quick example, use separate bend lines, plus and - degrees, and always
bend on the centerline of the thickness.
Bends.sfx (27kb) downloaded 13 time(s).
24c on 8/30/2023(UTC)
24c
#3 Posted : Wednesday, August 30, 2023 12:24:28 AM(UTC)
24c
Hi Larry
I never knew this about the middle bend line, I always thought you applied the line to the inside of the bend.
I'm going to redraw the part now, and apply your thinking.
Thanks again for taking the time to answer
Mike
24c
#4 Posted : Wednesday, August 30, 2023 1:47:48 AM(UTC)
24c
Hi again Larry,
It wasn't as simple as I thought, took some attempts & undos before it managed it...
Mike
