JamesColella
#1 Posted : Wednesday, September 6, 2023 10:38:09 AM(UTC)
JamesColella
Try as I may I know I'm doing something wrong. I've finally drawn the part I wanted. Now I'm needing to hollow it out, but I seem to be unable to get the shell tool to work. I think I did it wrong. I can't find a way to attach the file.
I've never used CAD before, so I'm learning as I go.
Can anyone help me?
Edited by user Wednesday, September 6, 2023 10:40:25 AM(UTC)  | Reason: Yes, I found how to attach at file.
Sleeve.0001.vc3 (12kb) downloaded 7 time(s).
24c
#2 Posted : Wednesday, September 6, 2023 2:01:50 PM(UTC)
24c
Was thanked: 64 time(s) in 46 post(s)
Hi James,
I'm assuming you want something like this?
Try looking at this... http://docs.imsidesign.com/projects/ViaCAD-v14/
but essentially select the shell tool, select the surface, and it will shell normal to the workplane, you can change the thickness in the dialogue boxes too.
Mike
Screenshot 2023-09-06 at 20.57.01.png (126kb) downloaded 3 time(s).
macOS Tahoe - v16 beta
