2D Drafting
Deleting part of a polygon?
For the life of me I cannot figure out how to delete part of a polygon. I draw a rectangle, place 3 lines (like a U) against the long edge of the rectangle (like a channel) and cannot delete the top portion of the "channel"- that part of the rectangle that would open the channel. Can anyone tell me how to trim polygons?
Edit: I just watched a video where Tim drew two polygons, one on top of the other like the Red Cross symbol and then deleted the inside lines of the polygon. I cannot do that in V 14. Anyone know why? What am I doing wrong?
Edited by user Friday, November 24, 2023 5:19:14 PM(UTC)
Thanks: 250 times Was thanked: 80 time(s) in 47 post(s)
Make sure to select the "single line" option in the polygon tool otherwise the trim tool will not work on the polygons created with the polygon tool.
Or use "Edit:Change Object Type" to change the object type of the polygons to lines before using the trim tool.
kind regards
Danny
Edited by user Friday, November 24, 2023 6:42:45 PM(UTC)
damhave attached the following image(s):
(158kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
BR Danny Win10 Pro, SharkCAD Pro v14(1653) v15(1722) Dell XPS 15 Sonoma 14.7.1 SharkCAD v14 Pro(1653), MacBook Pro 14 2023,M3
3 users thanked damhave for this useful post.
Originally Posted by: damhave Hi, Make sure to select the "single line" option in the polygon tool otherwise the trim tool will not work on the polygons created with the polygon tool. Or use "Edit:Change Object Type" to change the object type of the polygons to lines before using the trim tool. kind regards Danny
Worked like a charm! I hadn't noticed you can choose a smart polygon or a line when you draw them.
Thank you,
Bill
2D Drafting
