Well, I used the line example as the simplest case of where I see this happen, but it happens on other tools too.
And I apologize for posting my two images in the wrong order, the right image is the initial case, the left image is the result.
Steps to reproduce:
1. Draw a line (I drew a vertical line, but any angle does the same)
2. Start drawing a second line, with the LogiCursor indicating "endpoint" of the first line (I drew a horizontal line, perpendicular to the first, likewise, any angle does the same)
3. Click to end the new line.
4. Start typing a length, which will automatically highlight and enter the text in the Length data entry field (I typed 4' --> number 4 and single quote for feet, using feet/inches units)
5. Hit return, and new line jumps off of the endpoint of the first line.
Alarmingly, Tim's suggestion of trying the Multi-Line tool exhibits the same behavior...
1. Start drawing a line
2. Before clicking to place the second point, type 2' and hit return
3. On mouse movement, line and cursor jump
--> The first attached image shows a sequence of drawing arbitrary angled lines, and entering 2' before clicking the endpoint.
Then I tried a variation, manually dragging out to 2' a couple times on the first two line segments, then on the third typing in the 2' value, and the multi-line jumps off the end of the first two (well behaved) lines. Screen shot attached.
--> The second screenshot sows a multi-line created by dragging out manually to 2' twice, then typing the 2' value for the third line.
Edited by user Wednesday, November 22, 2023 12:53:04 PM(UTC)
epicycloid attached the following image(s):
(29kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
