Push Pull tool not making holes
As mentioned in the description. I make a circle and go to push the circle using the push pull tool but it only extrudes and doesn't make a hole. Never had this problem before, so now I'm stuck at this point because I can no longer make holes other than from a circle in the 2d drawing. At this point the software is completely useless if I can't make holes where needed. Mac OS Sonoma 14.2.1 Viacad 14.1 build 1641.
Thanks: 42 times Was thanked: 42 time(s) in 29 post(s)
Hi Truggy I'm a windows user so cant help you there. Not sure if this helps. As a workaround until it gets sorted. Perhaps extrude a cylinder. Align it with the circle on the solid and use the subtract tool to create the hole you want. Not ideal but keeps you moving.
Thanks: 34 times Was thanked: 50 time(s) in 37 post(s)
Hi Truggy,
I'm using the same OS, but I never use the Push Pull tool to make holes, just this one "CutOut Solid", which takes any closed planar group and makes a hole through a solid for a given direction ("z" in my case).
Mike
Edited by user Wednesday, January 10, 2024 1:26:16 AM(UTC)
| Reason: Clarity
(151kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 1 times Was thanked: 6 time(s) in 2 post(s)
Hi Truggy,
I'm using Sharkcad v14.0 build (1625)
PowerPacked
Windows
Sometimes I had the same problem
After using: Tools-Snap-
Face on to draw the circle to push-pull it works great for me.
But the answer from 24c also does the job...
Good luck, Theo
Edited by user Thursday, January 11, 2024 10:54:14 AM(UTC)
If things don't go the way you would find a way it could.
You will have to draw the circle on the surface, dead on. After, you select the circle and then use the push-pull and it should do the negative instead of extruding. That's how I know it.
Thanks: 135 times Was thanked: 35 time(s) in 22 post(s)
It seems to work for me (tested on Mac OS Sonoma 14.2.1 SharkCad 14.1. OBS with buiild 1645. But sometimes I have to select both the face and the circle with the select tool before it will extrude. Extrude works in both directions - no problem with holes. kind regards Danny
BR Danny Windows 10 Pro, SharkCAD v14 Pro (1653), XPS 15,9980HK Sonoma 14.3, SharkCAD v14 Pro (1653), MacBook Pro 14 2023,M3
I ended up closing the program and reopening it and it works now, but unfortunately I'm having a more severe problem now w/ my models will just disappear without a trace when zooming out. I'm not zooming out so far that I can't see the model but the second I start to zoom out the model just dissapears. This has happened twice now.
