TruggyDriver69
#1 Posted : Saturday, January 20, 2024 1:25:04 PM(UTC)
TruggyDriver69
As the title says the dropdown menu is frozen and can't be closed unless I click a different dropdown menu. I went to save my project via the dropdown menu but it won't let me select anything in the menu and it is completely frozen. I can click on other dropdown menus but can't click on any of these menu options. Also I am unable to close the program and force quit is not working. Mac OS Sonoma 14.2.1 ViaCad 14 build 1641. /Users/donpetersen/Desktop/Screenshot 2024-01-20 at 1.11.06 PM.png
Screenshot 2024-01-20 at 1.11.06 PM.png (1,090kb) downloaded 6 time(s).
damhave
#2 Posted : Saturday, January 20, 2024 1:40:50 PM(UTC)
damhave
Denmark
Was thanked: 35 time(s) in 22 post(s)
Build 1645 should solve the menu problems on Mac OS Sonoma 14.2.1.
I run 1645 (SharkCad) on the same OS on my mac and don't have any menu problems.
WIP build 1645 download link can be requested here:
http://masterviacad.com/beta/beta.php
Kind regards
Danny
Edited by user Saturday, January 20, 2024 1:41:39 PM(UTC)  | Reason: Not specified
BR
Danny
Windows 10 Pro,
SharkCAD v14 Pro (1653),
XPS 15,9980HK
Sonoma 14.3,
MacBook Pro 14 2023,M3
TruggyDriver69
#3 Posted : Saturday, January 20, 2024 3:18:53 PM(UTC)
TruggyDriver69
Thanks I'll give it a go and hopefully it works out.
TruggyDriver69
#4 Posted : Sunday, January 21, 2024 8:19:01 AM(UTC)
TruggyDriver69
Downloaded and installed build 1645 and now it's worse, much worse. Constantly freezing up and I have to force quit the program because ViaCad 14 (not responding). The program is pretty much useless as it keeps freezing and it won't let me save any work.
TruggyDriver69 attached the following image(s):
Screenshot 2024-01-21 at 7.05.28 AM.png (290kb) downloaded 1 time(s).
24c
#5 Posted : Sunday, January 21, 2024 10:28:47 AM(UTC)
24c
Was thanked: 50 time(s) in 37 post(s)
Hi Don,
I had this issue with macOS and earlier builds, and the workaround before build 1645 was to access the Apple Menu on the right hand corner, and click on something here, which broke the bug. I did use the hot keys Shift Cmd Esc to Force Quit, but it was a nuisance.
After 1645, like @damhave this disappeared for me, and I'm using an external monitor on a MacBook, which might be different to your setup
Have you tried going into ViaCAD's Preferences/Settings and resetting the Defaults on your latest build incase something in your settings has corrupted something? You might have to move your windows and dialog boxes around afterwards
Mike
TruggyDriver69
#6 Posted : Monday, January 22, 2024 8:07:26 AM(UTC)
TruggyDriver69
Yea I have tried everything. I'm using a 2019 16gb i7 6 core Intel MBP. Im pretty positive that It's Sonoma causing the issues at this point.
#7 Posted : Wednesday, January 24, 2024 5:28:22 PM(UTC)
Can you confirm it says 1645 in your about box?
TruggyDriver69
#8 Posted : Thursday, January 25, 2024 3:56:40 PM(UTC)
TruggyDriver69
Hi Tim. I had to downgrade to 1616 and so far no issues, but I’ve only used it once since then. I still have the 1645 wip dmg file on my Mac as all the pat updates as a just in case measure. I think this is a Apple issue for the most part.
