Jean-Francois Jacques
#1 Posted : Monday, February 5, 2024 4:13:20 PM(UTC)
Canada
Was thanked: 29 time(s) in 21 post(s)
Tim, definitely I don't have success with the variable Blend Tool !!
1- In concept explorer try to remove "Fillet (Variable)_REMOVE" = That will be delete also Fillet (Variable)_2
2- Look the inconsistent values for Fillet (Variable)_1 (I want 0.040" - 0.040" - 0.140" - 0.140")
3- Impossible to do a variable fillet for Fillet (Variable)_2 (all variable are 0.040 ") I want 0.040 - 0.140 - 0.040"
What is wrong !!
Add-On Pedals.sfx (3,846kb) downloaded 16 time(s).
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
thanks 2 users thanked Jean-Francois Jacques for this useful post.
damhave on 2/6/2024(UTC), jlm on 2/9/2024(UTC)
damhave
#2 Posted : Tuesday, February 6, 2024 11:31:58 AM(UTC)
damhave
Denmark
Was thanked: 35 time(s) in 22 post(s)
I see the same problems (tested on my macbook w/ Sonoma)
kind regards
Danny
Edited by user Tuesday, February 6, 2024 11:53:57 AM(UTC)  | Reason: Not specified
BR
Danny
Windows 10 Pro,
SharkCAD v14 Pro (1653),
XPS 15,9980HK
Sonoma 14.3,
MacBook Pro 14 2023,M3
#3 Posted : Friday, February 9, 2024 2:42:36 AM(UTC)
Was thanked: 151 time(s) in 96 post(s)
What is wrong !!
Hi Jean-François,
I also noticed several bugs on the last build with the blend tools that I didn't have time to report yet.
Even constant blends : Eliptic and vertex are not working at all (the menu is not responding).
JL
#4 Posted : Friday, February 9, 2024 5:11:42 PM(UTC)
Canada
What is wrong !!
Hi Jean-François,
JL
Jim
Thanks for your comment !
I have also a big problem with the Push/Pull Tool. Inconsistent behaviour !!! Sometimes when I use it I loose the dialog window for my numerical value !!
I think Shark have a big problem with Sonoma!!
rockyroad_us
#5 Posted : Friday, February 9, 2024 7:58:50 PM(UTC)
rockyroad_us
It will be nice to highlight the location points from the inspector to figure out where the variable blends are taken. To me the variable blend was crashing the software when I modified the radius at any location. Maybe that got fixed.
#6 Posted : Saturday, February 10, 2024 3:27:12 PM(UTC)
Hi Rockyroad,
Variable blends seem to work perfectly now !
Though, with Constant blend, the choice menu " Radial, elliptical, Vertex" is not working... it sticks to "radial".
JL
damhave on 2/11/2024(UTC)
