I've updated the beta/WIP download links to now include:
ViaCAD 14 1649 (2D, 2D3D, Pro)
SharkCAD 14 1649 (SharkCAD, SharkCAD Pro)
Change Log --Setting pen colors on faces
--Crash exporting certain OBJ with 3D Text
--Render animations not working on Windows
--Record screen now working on Windows
--Drop down issues with Model to Sheet dialog
--More logs for solving registration issues
Download Download the beta at :
http://www.masterviacad.com/beta/beta.php Note Please keep in mind this is a WIP with limited testing. I would recommend you rename your existing version as backup prior to installing 1649 Mac or Windows.
Edited by user Sunday, February 11, 2024 12:23:20 PM(UTC)
Thanks: 135 times Was thanked: 35 time(s) in 22 post(s)
Hi Tim,
Sometimes the Display in Wireframe does not display anything. But The Display with shading works.
Like in the attached project with a 50x50x50 blue cube. I have observed this behavior 3 or 4 times.
kind regards Danny
(Tested on Sonoma 14.3)
Edited by user Saturday, February 10, 2024 1:36:29 PM(UTC)
Missing wireframe.sfx
(11kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
BR Danny Windows 10 Pro, SharkCAD v14 Pro (1653), XPS 15,9980HK Sonoma 14.3, SharkCAD v14 Pro (1653), MacBook Pro 14 2023,M3
1 user thanked damhave for this useful post.
Thanks: 211 times Was thanked: 151 time(s) in 96 post(s)
Originally Posted by: damhave Hi Tim, Sometimes the Display in Wireframe does not display anything. But The Display with shading works. Like in the attached project with a 50x50x50 blue cube. I have observed this behavior 3 or 4 times. kind regards Danny (Tested on Sonoma 14.3)
Hello Danny,
I confirm Wireframe is not working on your cube.
Strange : if I change color of one face of the cube, and then move this face ---> The color change is canceled and .... the wireframe is back working..
Is it a hint Tim ?
Jean-Louis
1 user thanked jlm for this useful post.
There is a Move Face feature operation with a move direction of (0,0,0) which is invalid. If you Remove Feature, it should be ok.
I need to see if I can recreate how that move feature of (0,0,0) got assigned and correct.
Edited by user Saturday, February 10, 2024 5:35:34 PM(UTC)
(342kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
@Tim, Thanks, I have only observed the missing wireframe issue with the new 1649 build and only after assigning colors to two or more individual faces with "Select Deep" and by change the color via the context menu or inspector. Then when changing the colors again it sometimes happens..... (I probably also did som rotation of the view with the navigator which I use a lot) Kind regards Danny
Thanks Danny for the background info. I suspect when we are clicking on the face it is somehow detecting a face drag and putting that bad feature into the tree. That should be enough info for me to check further into a fix.
Edited by user Sunday, February 11, 2024 12:24:05 PM(UTC)
Hi Tim,
I noticed a minor issue with the display of a hexagon cut-out in a solid with 14.10-1649 ViaCAD pro. After adding a 30 degree chamfer on the hexagon edge cut-out, one edge will display an incorrect chamfer angle. This was also the case in the previous WIP version.
Dan
Hexagon Chamfer.vcp
(55kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked Danlee for this useful post.
Originally Posted by: Danlee I noticed a minor issue with the display of a hexagon cut-out in a solid with 14.10-1649 ViaCAD pro. After adding a 30 degree chamfer on the hexagon edge cut-out, one edge will display an incorrect chamfer angle. This was also the case in the previous WIP version. Dan
Yes, it seems that the reference face for the chamfer angle is not the same for every edge.
Same trouble with "Two length" chamfer.
Also with Sonoma : dysfunctional chamfer menu
(271kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
This is fixed in the next build impacting Mac and Windows builds. Same for radial menu.
3 users thanked Tim Olson for this useful post.
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Using build 1649 I can't seem to change an objects layer from the inspector window. I select an object, go to inspector attributes pane and the Layer drop down - select a different layer and "apply" and the layer goes back to what it was. If I right click on the object and select Layer and choose a different layer, that seems to work.
I'm on a Mac: 13.6.4.
I also just noticed that I can now deep select a face and change the color of that face, but if I save the file, close it and re-open the file the colors are gone. If I select the face again, the "Object Pen" shows the color that I set it to, but it just displays the base color of the object.
Edited by user Wednesday, February 14, 2024 7:50:16 AM(UTC)
1 user thanked strangebru for this useful post.
>>select a different layer and "apply" and the layer goes back to what it was. I can't seem to repeat this but will keep looking into.. >>but if I save the file, close it and re-open the file the colors are gone. This should be fixed in 1650. Tim
Thanks: 2 times Was thanked: 29 time(s) in 21 post(s)
Originally Posted by: Tim Olson >>select a different layer and "apply" and the layer goes back to what it was. I can't seem to repeat this but will keep looking into.. >>but if I save the file, close it and re-open the file the colors are gone. This should be fixed in 1650. Tim
Tim did you see my post about the gripper ?
Thanks: 4 times Was thanked: 38 time(s) in 24 post(s)
WIP 1649 Mac 11.7.1: Constant Chamfer -> It is not possible to select another type. If you try to select "Two Length", it will jump back to "Length". Tested with 1645 and it works.
Edited by user Thursday, February 15, 2024 8:38:44 AM(UTC)
2 users thanked relaxibus for this useful post.
PDF 2D Export doesn't work. PDFs seems to be corrupted. Same with 1645. Mac 11.7.1
1 user thanked relaxibus for this useful post.
Originally Posted by: relaxibus WIP 1649 Mac 11.7.1: Constant Chamfer -> It is not possible to select another type. If you try to select "Two Length", it will jump back to "Length". Tested with 1645 and it works.
For me it is the opposite. It just resort back to Two length possibly from a previous design which uses two lengths. Now with any file it will not move to any other choice then to Two Lengths.
Originally Posted by: relaxibus PDF 2D Export doesn't work. PDFs seems to be corrupted. Same with 1645. Mac 11.7.1
Would it be possible for you to post a file that does not work. It may be a object type I'm not testing.
AllEntititesV14Materials.pdf
(419kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
Here the file
CONST_LABJOY_SEALING-GASKET.sfx.zip
(257kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Hello Tim,
using ViaCAD Pro with Powerpack build 1649 on Windows 10 Pro and found following subjects not working for me:
- Tool window 'Render Library': only item 'HDR Backgrounds' is selectable, not 'Backgrounds', 'Materials' or 'Texture'. If I'm trying to select one of the last 3 items 'HDR Backgrounds' stays selected.
- Trying to use 'Object Animate' is only successful if I choose 'OpenGL to Screen', except for the attached texture which is removed throughout the movement. After the movement the texture is recovered.
'PhotoRender to Movie' is rendering 21 frames in spite of the setting '# Frames' = 20.
The Progess Window' isn't showing a preview.
Sometimes no AVI-File is generated. I have no idea what that depends on. In this cases even no file 'lux_log.txt' is generated.
When an AVI file is created, the first bytes do not appear to have any meaningful content. I've attached a screenshot of my hex-reader.
Wolfgang
Elektroniker attached the following image(s):
(42kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
- Tool window 'Render Library': only item 'HDR Backgrounds' is selectable, not 'Backgrounds', 'Materials' or 'Texture'. If I'm trying to select one of the last 3 items 'HDR Backgrounds' stays selected. Checking... - Trying to use 'Object Animate' is only successful if I choose 'OpenGL to Screen', except for the attached texture which is removed throughout the movement. After the movement the texture is recovered. 'PhotoRender to Movie' is rendering 21 frames in spite of the setting '# Frames' = 20. The Progess Window' isn't showing a preview. Sometimes no AVI-File is generated. I have no idea what that depends on. In this cases even no file 'lux_log.txt' is generated. When an AVI file is created, the first bytes do not appear to have any meaningful content. I've attached a screenshot of my hex-reader. I thought this was addressed in 1649. I will double check and make sure the changes are merged in 1650. Tim
Thanks: 13 times Was thanked: 21 time(s) in 14 post(s)
Tim did you see my post about the gripper Yeah, what was it? Mines broken in 1649. User position and at selected doesn't work :-(
1 user thanked CADCAM for this useful post.
