Jimbl
#1 Posted : Wednesday, April 17, 2024 4:51:08 PM(UTC)
Jimbl
Hello, I have two problems related to one file. My horizontal and vertical dimensions seemed to be switched. Both vertical and horizontal always read zero and the zero is oriented 90degrees to the line.
I think this also related to the arrow keys. The arrow keys are opposite of what you expect in the top view. Another thing i just discover when i type words they look fine, as soon as i hit enter they rotate 90 degrees .
This only happens in one file.
I would love to sort this out
Thanks Jim
Edited by user Wednesday, April 17, 2024 4:58:35 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, April 18, 2024 2:07:13 AM(UTC)
I think you are working in a work plane that is not identical to the view. It's best to use dimensions and text only in the top view, or better yet, in the drawing derivatives.
Jimbl on 4/18/2024(UTC)
