bsd_mike@yahoo.com
#1 Posted : Monday, November 11, 2024 10:29:51 AM(UTC)
bsd_mike@yahoo.com
I have followed this tutorial very well, right up to the part about trimming the excess from the top and bottom.
https://youtu.be/UGmfM2wQhWc?si=AZXv1_2Mcuvd0jNl
I am probably pretty thick. but I can't figure out how to use the infinite plane and trim.
I have watched the video several times, but that part seems to go by quickly.
It looks so easy on the video!
I have some thread sticking out on the top and bottom of my part.
Also, how can I check that the threads I created are attached to the part??
Thank you,
Mike
rockyroad_us
#2 Posted : Monday, November 11, 2024 12:51:48 PM(UTC)
rockyroad_us
about checking the thread to the part, just move the main shaft around, they should move together; or check the shaft on the explorer having the add solid command in the history.
#3 Posted : Monday, November 11, 2024 2:08:47 PM(UTC)
Was thanked: 187 time(s) in 133 post(s)
Trim Tool with Specified Vector:
Specify 2 Points for Trim Sweep Direction: Define two points to establish the direction of the trim sweep.
Select Curve or Surface to Trim Solid: Choose the curve or surface that will be used to trim the solid.
Select Solid to Trim: Identify the solid you wish to trim based on the specified direction and selected curve/surface.
This sequence allows you to trim solids by defining precise sweep directions using points, curves, or surfaces.
Edited by user Monday, November 11, 2024 2:28:44 PM(UTC)  | Reason: Not specified
GARLIC on 11/11/2024(UTC), bsd_mike@yahoo.com on 11/11/2024(UTC)
bsd_mike@yahoo.com
#4 Posted : Monday, November 11, 2024 3:19:30 PM(UTC)
bsd_mike@yahoo.com
I think I got it!
Thank you!
