Right-Click selection issue
Thanks: 74 times Was thanked: 89 time(s) in 58 post(s)
Bug, or feature? I'm on SharkCAD Pro, v12, Win 11. The two following examples of arriving at my problem probably aren't yhe only way to see my problem. Here are two examples. Use curves to create a simple surface. If you have Power Pack, go to Draw, Surface Grid Do it once or twice. Select the surface and ONLY the surface. Right-click/contextual-click on the surface. Select Hide. Then, select what remains. Then, Go to the Concept Explorer, Entities, and look for the the one or two Surface Grid objects. Alternatively, create two or more surfaces and underlying solids. Select something and use right-click Hide. Depending upon the topological position in space — and not necessarily what's in the feature tree, you sometimes get hidden something you didn't want hidden. It's not following the same logic as right-click selecting geometry and using the shortcut key (in my case, H) to hide something. It seems that the right-click contextual operation re-selects randomly, and not necessarily what you want to operate on. Can anyone wlse reproduce this?
