#1 Posted : Friday, August 29, 2025 2:40:55 PM(UTC)
Was thanked: 122 time(s) in 82 post(s)
I finally figured out how to put an end to a problem that dogged me for months and was intermittent.
Go to:
SFXPrefs.ini
Scroll down to [DEFeatureFilter]
You can comment out each line one at a time, but, going so will collapse the (in my case, 9; I used ;) lines to one row
Alternatively, using a test copy, just delete the section to confirm that SOMEthing there in that section is the culprit, and restore one by one.
I looked in the Prefs section under File, Preferences...
Nothing in there gave a clue nor had any effect I could guess at.
I spent maybe two hours duplicating, subdividing, and testing folders filled with copies of the files under AppData/Local/Punch!/SharkCAD.
I almost did a full. But, something said delete the .ini files and see what comes back plain and default.
Then something said back up the .ini files run them with one at a time an absence. Took almost two hours before I narrowed down the file, then randomly snipped until the selected geometry resumed appearing.
The above my post to the fol:
