MARTINEAUJL
#1 Posted : Sunday, November 23, 2025 5:54:36 AM(UTC)
MARTINEAUJL
In 3D mode with ViaCad 16 Pro.
No constraints enabled
Normal work plane (front, top, or side)
Polyline tool enabled
It's not possible to draw more than two segments by directly entering the coordinates.
This works perfectly in 2D mode.
Is there a specific technique for this?
Thank you for your answers and tips.
thanks 1 user thanked MARTINEAUJL for this useful post.
ZeroLengthCurve on 11/23/2025(UTC)
Theo5715
#2 Posted : Wednesday, November 26, 2025 11:29:04 AM(UTC)
Theo5715
Netherlands
Was thanked: 32 time(s) in 19 post(s)
Hi Martinraujl,
I work with Windows Sharkcad 14, build 1625 and no problems with it.
Perhaps you have to look at the preferences/user interface and select or unselect "use workplane coordinates in data entry"
Maybe this helps?
Regard, Theo
Edited by user Thursday, November 27, 2025 12:04:45 PM(UTC)  | Reason: Not specified
Theo5715 attached the following image(s):
If things don't go the way you would find a way it could.
Win11-Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz (3.60 GHz)RAM-32GB
thanks 1 user thanked Theo5715 for this useful post.
MPSchmied on 12/1/2025(UTC)
