24c
#1 Posted : Monday, December 22, 2025 9:44:05 AM(UTC)
24c
Was thanked: 70 time(s) in 51 post(s)
This dropped on my Youtube feed a little while ago, so I was intrigued.
I thought the idea of using AI to remove redundant items from your feature tree to be pretty cool
Link to Adam
Mike
Edited by user Monday, December 22, 2025 9:45:05 AM(UTC)  | Reason: Not specified
macOS Tahoe - v16 beta
ZeroLengthCurve on 12/22/2025(UTC)
#2 Posted : Monday, December 22, 2025 2:59:55 PM(UTC)
Was thanked: 105 time(s) in 67 post(s)
Thanks!
I have 13 or 14 bullet points that took me about 45 minutes to draft.
Here's an excerpt (just six):
— finding non-symmetrical control points and automatically balancing them or by teaching the user how to apply constraints (thank you, a 2nd time, 24c, as I only thought of this while drafting my response to your post) tho, if mirrored, constraints-based control points reach a crazy-high amount, constraints will be a severe maintenance issue for the human;
— allowing the user to sort or to relabel and re-sort names of sub-layers;
— allow the user to select layers to actually be physically, not sleight-of-hand cosmetically grouped, moved outside of their current nested layer;
— keep realtime track of the last 2,000 actual edits, and be ready to INSTANTLY redo the work for the user after a crash;
— keep track of the recent 10,000 edits that might have contributed to file corruption;
— eradicate from or totally separate from the Undo stack ANY ACTIONS that are not geometry; really, administrative things should be in a separate undo stack so that admin-type acts that might spawn dozens of sub steps could swarm the undo stack to the point of busting it really fast, making Undo and Redo untrustworthy — I had to bail out of/quit a file because the Undo stack got goofy);
#3 Posted : Monday, December 22, 2025 3:13:59 PM(UTC)
I just watched the video in the link.
It reminds me of a video YouTube just days ago dropped into my feed. I can't remember the app. It has a "smart" feature that recognizes intent of moving a shaft and some collart and auto aligning the holes and pins, sparing the user of editing all sorts of constraints.
I do remember the video showing a truck that has inside in a body akin to a garbage truck a pair of shafted augurs that dispense feed to cattle.
In the front of the bay (but behind the driver's cabin) are two parallel motor spindles. Something like 6 or 8 different employees in the US and in South America are shown showcasing features of the app.
#4 Posted : Monday, December 22, 2025 3:28:08 PM(UTC)
I feel compelled to share two more suggestions not in my excerpt I posted above:
— immediately recognize that high-tedium geometry creation, such as creating ship hull stiffening anolg a compound curvature along >100 meters can be done by replicating the user's steps (of the user has a plan, and can explain such as "every x meters, between these points...) to do in 3 minutes what might take (me) 3 hours;
— auto-fair, by analyzing user apparent intent, 3D/compound curvature interpolated and even control point splines so that a spline that is the top deck, various waterlines, profile, and body plan (front/bow view, as well as its rear/stern view) can be constrained so the user need not play with excessive amounts of constraints in a valiant effort to make a faired hull;
As for the Adam video, I don't know if that company is going along a path of trying to patent anything as if no other CAD app makers thought of what the video presents, but, it feels like
— Tim's Copilot;
— various features of FreeCAD; featues in Rhino/Grasshopper/Orca/Nemo/Swordfish; and
— other's apps which I've watched that have been or seem to be offering comparable features.
Perhaps a "moat" Adam may have is a clean sheet CAD system? Could it be one devoid of 20+ years of spaghetti minefield code that even an AI regression analysis would overheat past 10 million degrees Kelvin?
