2 Pages<12
L. Banasky
#21 Posted : Saturday, June 13, 2026 3:16:59 PM(UTC)
L. Banasky
Was thanked: 161 time(s) in 111 post(s)
Hi Luis,
Do you still have Ver12. on your computer or another computer?
On my PC Ver12. will open Ver14. files, which is strange, also shares the same shortcuts etc.
Maybe give that a try.
Theo5715
#22 Posted : Sunday, June 14, 2026 2:41:20 AM(UTC)
Theo5715
Netherlands
Was thanked: 43 time(s) in 27 post(s)
Today I did send a mail to sales@imsidesign.com
Not for me, just to see what's happening...:-)
Dear sirs,
I would like to buy a new computer, and I am wondering if I can re-install my Sharkcad12 software and the Sharkcad14 Pro upgrade using the accompanying keys without problems?
If there are some special handlings for it please let me know.
Kind regards,
If I get an answer I will let you know.
Edited by user Sunday, June 14, 2026 2:44:20 AM(UTC)  | Reason: Not specified
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
thanks 1 user thanked Theo5715 for this useful post.
lgrijalva on 6/15/2026(UTC)
#23 Posted : Sunday, June 14, 2026 4:43:20 AM(UTC)
Was thanked: 216 time(s) in 149 post(s)
Originally Posted by: lgrijalva Go to Quoted Post
Than could be a way to use my old license? I am affraid that IMSI will try to charge even more if on trying to validate that oldonwy (Think the oldest one I have is from Shark FX v5)
And Actually, if I try to install in another platform os or computer I will give them arguments to claim that is actual a support issue due to migration hardware or platform cahange or whatever (Of course I will not agree whit this either)
But in my case, I am trying to validate the same installed version on the same computer on the same version of OS that was already working on, and suddenly that day won't work and ask for license validation again, this should't be a support issue, validation process should work seamlessly.
Now I am suspicious about that actually is not really a fail of validation system, is just faking the fail (unless the system bans serial keys due to purchase dates, that is a practice that must be be ilegal) to force you to ask for support. becase both DRM system (Online and offline) are not returning any feed back, I mean, no wariness as "your license is out of automate service now" or that one that use to be "your already use the validation available number for you license" or any other.
So I am still stucked on same status
No answer form legal department
No news from Todd
My license still hijacked, and me exploring and decide which will be my new working software for design and work too
Thanks for your collaboration and help my friends
Test the activation on another computer or in VMware. Using different software not only costs more money, it also takes a lot of learning. I tried to reach Tim Olson by email — no response. It seems he is in the Bahamas.
Edited by user Sunday, June 14, 2026 4:45:11 AM(UTC)  | Reason: Not specified
#24 Posted : Sunday, June 14, 2026 9:20:46 AM(UTC)
Was thanked: 112 time(s) in 74 post(s)
Speaking of DRM, I recently read that DRM has been found to be the cause of some failed 911 emergency calls. Not sure if it's USA-specific or of the 911 also applies to 119 in Asia and Europe.
It would be a relief of your issues are related to a flaw in DRM and not some management of financial action.
thanks 1 user thanked ZeroLengthCurve for this useful post.
lgrijalva on 6/14/2026(UTC)
#25 Posted : Sunday, June 14, 2026 10:23:00 AM(UTC)
Originally Posted by: ZeroLengthCurve Go to Quoted Post
Speaking of DRM, I recently read that DRM has been found to be the cause of some failed 911 emergency calls. Not sure if it's USA-specific or of the 911 lso applies to 119 in Asia and Europe. It would be a relief of your issues are related to a flaw in DRM and not some management of financial action.
No, the registration process has nothing to do with DRM. It requires neither digital rights management hardware nor related software.
Edited by user Sunday, June 14, 2026 10:26:01 AM(UTC)  | Reason: Not specified
thanks 3 users thanked MPSchmied for this useful post.
GARLIC on 6/14/2026(UTC), lgrijalva on 6/14/2026(UTC), ZeroLengthCurve on 6/14/2026(UTC)
#26 Posted : Sunday, June 14, 2026 10:15:42 PM(UTC)
Hello
Not sure if I am understanding, Registration process for shark it seems to use DRM system as validation to activate the license, both cases, the automatic online connects to a server managed license an is called DRM, an the offline process to validate, give instruction to connect to webadres drm.imsidesign.com (that redirects to https://encore.cloudflar...login/drm.imsidesign.com), you can notice this if yo try to do an offline validation if when your computer does not have internet access (I tried this when automatic validation doesn't work) and, it doesn't work also (I try on a mobile phone for example an other computer, tried both, none of them works), it supposes to return a code by email that you write on the site and gives access to page were yo write an installation code ant it gives you back an activation code, but that mail never come (and no error o warning about anything as well)
This are the mains screens for that process:
Edited by user Sunday, June 14, 2026 10:34:20 PM(UTC)  | Reason: Not specified
MacOSX Sequoia 15.7.7
thanks 2 users thanked lgrijalva for this useful post.
GARLIC on 6/14/2026(UTC), ZeroLengthCurve on 6/14/2026(UTC)
#27 Posted : Monday, June 15, 2026 3:29:29 AM(UTC)
Are you sure that you have completely disabled all your spam filters, or, if you do not have spam deleted from the server, that you have checked your spam folders?
Theo5715
#28 Posted : Monday, June 15, 2026 10:22:29 AM(UTC)
Theo5715
Netherlands
----------NEWS FROM TODD BUT NO NEWS---------------
Hi Theo,
You would not need to install the V12 and then install the v14 upgrade over it. You could simply install the V14 as it will install as a stand alone program.
In saying that, however.
Unfortunately, With the date of your purchase of the v14, the maintenance and support period has expired. Programs come with a free year of Maintenance and support where we can supply you with download links and update keys for you.
I have two options for you. First, I can offer you our full upgrade discount pricing to the current v16 product, which will not only renew your maintenance and support services but move you up to the current version with all its updates, new features and tool enhancements. The cost of this upgrade is $699.99USD and you can use the link below to do so and change the upgrade from menu to SharkCAD/SharkCAD Pro <5yrs
​https://www.punchcad.com/sharkcad-pro-upgrade
The second option is to renew your Maintenance and support plan for a year. This is a good option if you do not want to upgrade, as it will allow us to provide you with links and maintain your key for another year.
Below is the full explanation of the Maintenance and support package
Ensure Continuous Excellence with Our Maintenance & Support Renewal
We understand the importance of keeping your products running smoothly and efficiently. Our Maintenance & Support plans are designed to provide you with the peace of mind that comes from knowing you have access to the latest patches and dedicated technical support.
Why Renew Your Maintenance & Support Plan?
Continuous Access to Technical Support Our expert support team is always ready to assist you with any technical issues or questions you may have. With a renewed plan, you can ensure that your work is never interrupted and that you always have the help you need.
Software and Maintenance Patches Stay ahead of the curve with the latest software updates and maintenance patches. These updates are crucial for keeping your software secure, efficient, and compatible with the latest technologies.
Peace of Mind Renewing your Maintenance & Support plan means you can focus on your projects without worrying about potential software issues. Enjoy the confidence that comes with knowing you have ongoing support and maintenance patches.
Our Maintenance & Support Policy
Validity: Maintenance & Support plans are valid for one year from the date of purchase and can be extended annually.
Coverage: These plans provide access to Technical Support and Software and Maintenance Patches.
Renewal: Maintenance & Support Renewal is available for versions up to 5 years old.
The cost for this is 25% of the retail cost of the current version or $499.99 for a year of Maintenance and Support. I would be happy to explain how to renew your support plan if you choose this option
Todd - Sales Manager
Punch Software | Customer Service
www.punchcad.com | www.punchsoftware.com
On Sun, 14 Jun at 1:54 AM , Theo <info@................nl> wrote:
Dear sirs,
I would like to buy a new computer, and I am wondering if I can re-install my Sharkcad12 software and the Sharkcad14 upgrade using the accompanying keys without problems?
Kind regards, Theo Breedveld
punchsoftware powered by Freshworks 65460:917572
thanks 2 users thanked Theo5715 for this useful post.
lgrijalva on 6/15/2026(UTC), MPSchmied on 6/15/2026(UTC)
#29 Posted : Monday, June 15, 2026 11:28:11 AM(UTC)
Yes, as well as checking the spam folder just in case (several times), but none mail has arrived form the DRM server
#30 Posted : Monday, June 15, 2026 1:28:42 PM(UTC)
Hi Theo,
Unfortunately, With the date of your purchase of the v14, the maintenance and support period has expired. Programs come with a free year of Maintenance and support where we can supply you with download links and update keys for you. .....
Theo
Thanks for testing this
Actually it seems as almost an automated answer reply, the text I received on my first request is very similar to this one you Get
Answer you get from Todd confirms that IMSI has converted da license hijack practice as financial strategy and the Todd's answer completely confirms my worst fears. This is not an isolated technical glitch; it is a calculated, systematic corporate policy to hijack our assets.
Look closely at Todd’s response. He explicitly states that paying the $499 maintenance fee is required to “maintain your key for another year.” Let that sink in.
By definition, a perpetual license means the key belongs to the user indefinitely. If IMSI requires an annual ransom just to 'maintain' the validity of a key you already paid for, it is no longer a perpetual license—it is a forced subscription. They are intentionally weaponizing their DRM infrastructure and withholding activation keys to extract recurring revenue from loyal, long-time users.
This is text-book extortion of consumer rights. I have already escalated Todd and Syed's contractually non-compliant responses to their Legal Department, and I will be forwarding this exact thread as evidence to the FTC and the California Attorney General's Consumer Protection Division. We bought a product, not a ticket to be repeatedly forced to pay.
So my dear fellow, if for some reason yo have a hard drive crash, or hardware malfunction and you need to do any repair (it can even be an OS update with som incompatibility), be prepared to be force to either pay for an upgrade or a maintenance contract so you can be able to validate your legit license.
Honestly IMHO, this practice is extremely abusive, In may case, I did not change hardware, not upgrade hardware, not hardware crash, not even an upgrade or update OS, the only thing that may be related to this deactivation issue is a reset of NVRAM (as I said before, very common practice on MacOS on Intel based, to optimize and fix som preferences an permissions).
Unfortunately for me, this is not just a bad experience with IMSI's policies; it has directly disrupted my workflow, causing financial impacts that far exceed the cost of either option they offered me. However, giving in to this abusive strategy feels completely wrong. As a matter of principle, I would rather invest my time and money into a different software alternative than validate these practices—which, I repeat, are shockingly abusive. I have never encountered anything like this before.
Edited by user Monday, June 15, 2026 3:45:02 PM(UTC)  | Reason: Not specified
thanks 1 user thanked lgrijalva for this useful post.
L. Banasky
#31 Posted : Monday, June 15, 2026 2:24:34 PM(UTC)
L. Banasky
Perpetual, doesn't really mean perpetual. A user should be given a "dongle", which I personally despise, with the "perpetual license".
Or a code to transfer to another computer without paying a ransom each time you update your hardware or OS.
Just my $.02, I went through that crap with the dongle that would only work plugged into the motherboard, not using an AB switch, had to install another board for the printer, years ago with Vellum3D or Cobalt, can't and don't want to remember.
Blood pressure is going up just reading these posts.
Edited by user Monday, June 15, 2026 2:34:02 PM(UTC)  | Reason: Not specified
#32 Posted : Monday, June 15, 2026 7:52:58 PM(UTC)
Agreed with you Larry, Thanks
is this a recent situation?, cause I search the forum for similar case and just find a thread from bbuxons member that is from just 6 months ago, here it is https://forum.punchcad.c...ts&t=11226#post43443
And also here: https://forum.punchcad.c...ts&m=43414#post43414
So, seems that this practice just starting, hope that complains about it drive IMSI to rethink about this.
@bbuxon please tell us what happened? do you have a positive answer for this?
Edited by user Monday, June 15, 2026 8:15:42 PM(UTC)  | Reason: Not specified
2 Pages<12
