grumpygeek
#1 Posted : Thursday, November 27, 2025 1:53:50 PM(UTC)
grumpygeek
Hi all,
So I am trying to convince myself that upgrading is worth it.
My last upgrade a little less than 3 years ago when V14 came out, I have been a user since V8, upgrade to pro with V9, added powerpack with V10, upgraded at V12 and V14. I skipped V15 and have looked over V16 and I just don't see anything other than 'verify clearance' and 'arc slot polygon' that I would use. I mostly use solid modeling for 3d printing now and V14 Build 1625 has been the most stable of any of the releases for me and I would hate to lose that stability. Is there any new feature since V14 Pro that I should consider when making my decision?
I do want to support the product development, but I also have a number of products I have to juggle upgrades for and my cad usage goes in spurts, might be real active for 3 months and not touch it for 6 months or more.
Any killer feature I am overlooking?
Don Bailey (aka grumpygeek)
Edited by user Thursday, November 27, 2025 1:58:52 PM(UTC)  | Reason: missing words because my brain is faster than my hands
Theo5715
#2 Posted : Friday, November 28, 2025 5:57:38 AM(UTC)
Theo5715
Netherlands
Was thanked: 43 time(s) in 27 post(s)
Hey Don,
You are fully right not to upgrade to >V14 with powerpack and build 1625.
I'm also use it for 3D printing and solid modelling and sheet metal, nothing wrong with it.
As far as I could see almost nothing is changed as now you can place a bold on it's place by using constraints and the explanation how to do it takes 3 minutes!
In V14 I do it in a few seconds without constraints............
Kind regards & hopefully long live V14 with powerpack!
Theo
If things don't go the way you would find a way it could.
Win11-Intel Core i7-9700K CPU @ 3.60GHz RAM-32GB Shark14&Powerpack
thanks 3 users thanked Theo5715 for this useful post.
GARLIC on 11/28/2025(UTC), damhave on 11/29/2025(UTC), grumpygeek on 11/29/2025(UTC)
bbuxton
#3 Posted : Monday, December 1, 2025 8:02:04 AM(UTC)
bbuxton
Japan
Was thanked: 35 time(s) in 16 post(s)
Trying to move a license to a replacement workstation might make upgrading a necessity if my recent interaction with support is anything to go by.
I asked to unlock my current license (14) to a new computer and was told I should upgrade.
Still a bit shocked by the apparent policy change. First time this has happened since Tim persuaded me to send back the dongle when upgrading from the Concepts Unlimited v1 in 2005/6(?)
thanks 3 users thanked bbuxton for this useful post.
damhave on 12/1/2025(UTC), grumpygeek on 12/1/2025(UTC), memphisjed on 12/12/2025(UTC)
24c
#4 Posted : Thursday, December 4, 2025 4:52:50 AM(UTC)
24c
Was thanked: 73 time(s) in 53 post(s)
My problem is slightly different, although my use came is the same.
I'm running macOS Tahoe, so my v14 is totally unusable with frequent crashes, cursor lock outs, and Concept Explorer glitches, so my only option is to get v16, or get another Mac/Windows computer and not be able to open my existing saved v16 Beta test files.
Cynically not sure if anyone has noticed, after waiting for the Black Friday discount codes, the website upped the cost of the software vs the previous discount code that was offered, so the total cost is the same...
I never took screenshots, but to upgrade from a sub 5 year old version, it was $699 less 20% before vs $789 less 25% on the Black Friday deal.
Maybe it's my memory playing games, but this is a little naughty, if this is the case.
Mike
EDITED... if you open v14 and check for upgrade you get a couple of options in the dialog box... the upgrade link sends you to the original PunchCAD webpage with the $599 upgrade + $100 surcharge, on checkout add the PCBFCM25 discount code and bypass the higher cost link.
Edited by user Thursday, December 4, 2025 5:12:57 AM(UTC)  | Reason: Update
macOS Tahoe-v17 beta b1908
#5 Posted : Monday, June 8, 2026 6:00:52 PM(UTC)
Hello Bbuxton, I am actually having a similar problem, but trying to reactivate the same license on the same computer and punchcad support es telling me that I have to buy an upgrade for 699 USD or pay 499 for maintenance contract (was actually what i paid for license upgrade to V14 from previous one)
Please guys, check this thread and tell if your thoughts and support if you can on this case:
https://forum.punchcad.c...ts&t=11262#post43555
MacOSX Sequoia 15.7.7
#6 Posted : Monday, June 15, 2026 8:17:34 PM(UTC)
Hello Bbuxon
Do you have a positive final answer on this situation?
This happens to me and not happy with this policy, here a Tread about this topic: https://forum.punchcad.c...ts&t=11262#post43555
Hope you can't tell us your experience on this too
Luis G.
