David Gross
#1 Posted : Friday, December 18, 2009 12:27:15 PM(UTC)
David Gross
When doing a simple hole to a depth is there any other way to get the drill point besides going to the object properties.
David Gross
Dmg Design
Colgate, Wi.
#2 Posted : Friday, December 18, 2009 12:30:36 PM(UTC)
It would be nice to have the drill point option at the top with the other hole data, so you can select when you create.
#3 Posted : Friday, December 18, 2009 12:32:03 PM(UTC)
No sorry, I was out of space to put in the data entry window.
David Gross
#4 Posted : Friday, December 18, 2009 1:34:33 PM(UTC)
David Gross
What about being able to pick multiple locations so that if you pick 20 locations the holes show up as 1 in the object properties box and therefore only have to edit 1.
David Gross
Dmg Design
Colgate, Wi.
#5 Posted : Friday, December 18, 2009 2:37:19 PM(UTC)
Was thanked: 122 time(s) in 82 post(s)
But, what if later because of element modeling or analysis it is decided to vary the size of symmetrical or assymetrical drill holes. If they are all one item in a parts tree, then geometry would have to be removed, changed, or added.
I would presume that some sort of database (a future feature) such as SQLite or whatever Tim can license inexpensively embed into ViaCAD and Shark would relationally handle the parts nesting/grouping so that one could pick affected parts and just resize/constrain them individually or pairs or according to hand-selected locations. This might have positive impacts on presentation and manipulation of parts.
Just some presumptions on my part...
David Gross
#6 Posted : Friday, December 18, 2009 5:37:56 PM(UTC)
David Gross
That work's for me and it took 10 YEARS to get the drill point.
David Gross
Dmg Design
Colgate, Wi.
