rockyroad_us
#1 Posted : Sunday, May 18, 2014 10:12:03 AM(UTC)
rockyroad_us
Hi Tim and those under the umbrella,
I would like to suggest to be able to loft two surfaces with the value 0 for bulge. I find this tool very useful when I offset two similar surfaces and I want to enclose the perimeter with flat walls irrespective of the ruled surface command.
Normally, I need to start with a bulge of value 1 and then loft the edges which gives a curved surface between the edges. Then I switch to zero manual on the input box and do this back and forth manual input of 1 to zero.
The command does allow it to loft at zero but it won't do it if set to zero when going around the perimeter of the surface thus needing to put a 1. :rolleyes:
#2 Posted : Monday, May 19, 2014 2:57:57 PM(UTC)
Updated in build 1116 to allow bulge = 0
rockyroad_us
#3 Posted : Tuesday, May 20, 2014 12:03:56 PM(UTC)
rockyroad_us
A dream come true! Keep them coming!
