Save Problem, Parts disappear (#3325)
                MAC Powerbook G4, OS 10.5.8 Shark V5 I did the following: 1  Create 2D of trapazoidal sheet with constraints 2  Go to 3D, select the Lines of the perimeter of the sheet 3  Extrude to random thickness and change to proper thickness of .063 in control panel 4  Make Instance copy off extruded sheet, call it Top1 and put it in a new layer named Top So far, everything is fine. I change a controlling dimension and it flows through everything.:) 5  Save the file using Save As and put it in a new job folder 6  Quit Shark 7  Re-open shark after several hours ans session with Cobalt, quitting Cobalt before opening. 8  The only things in the file are the 2D constrained lines. Everything else is gone although the layers are there.:eek: What did I do wrong.:confused:
                ViaCAD 2D/3D V7 exhibits a similar behavior in that if a 3D drawing is opened into a 2D environment, all that will be visible is the 2D components. I shut down, restart, and select 3D environment, then open 3D my drawing. Granted, Shark is a different breed of cat, but give it a try.
                Thanks Richard, It seems to work if I select 3D before opening my drawing.
