Shark FX crash when scrolling with mouse (#979)
                I recently upgraded to Shark FX from Concepts V4 and am currently having a lot of trouble with crashing when  scrolling  on the mouse to bring the view closer. It has got to the point where it is almost a daily (very frustrating) occurrence and never had any problem in Concepts V4 on the same hardware (PC/ XP Pro ver 2002). Today I was in 3D and moved a solid with the shift key - whilst the solid was still highlighted, I scrolled to find the screen immediately locked. Only way I could close out was ctrl.alt.delete. I then ended task and clicked on save file window. When reopening the file, it comes up with file error - This file is damaged. Cannot read into application. If I then go back to my file folder, there are 2 versions of this particular file. One file has suffix sfx and this file is the corrupted one. The second version has suffix sfxA and works but without all the   modifications I was working on at the time of the crash.
                Can you send me a screen shot of your View:Shade Options dialog box?  Sounds like its crashing related to OpenGL.  This dialog box controls some of those settings.
                Sorry Tim cant get a screenshot. But I can tell you that Shade Options are set up as follows:
                Hello Glen
                Hi Nick - ATI Radeon Mobility X1600. File size is 4.15MB and quite complicated with maybe 20 layers. Any thoughts?? Thanks Glen
                Nick
                Hello Glen
                It's not the issue with Anti - aliasing is it ?
                Nick - The Object counts in the opened file are:
                jol wrote: It's not the issue with Anti - aliasing is it ?
Thanks for your involvement Jol
Glen
                Glenw wrote: Nick - The Object counts in the opened file are:
Nick
Just found that this card has 256MB RAM thanks
Glen
                Glen - can you please confirm .. this happens with different files open - not just a particular one ?
                Hello Glen
                nick wrote: Hello Glen
Nick I will try that. Havent downloaded any drivers since purchase a couple of years ago thanks
                jol wrote: Glen - can you please confirm .. this happens with different files open - not just a particular one ?
Jol
Have been working on this file exclusively for a month and the problem has only existed on this file so far so I cant say for sure but probably exclusive to this file. AA is off. Have run verify-check objects with nothing showing up. The file is now 40 layers so I think I will paste in selected objects to a new file and start with a clean slate. Hopefully that will solve the problem. Will also download latest driver for the ATI card and for your reference running XP Pro. Vista had just been launched when I purchased the laptop and the recommendation was to stay with XP Pro. Anyway thanks for your help
Glen
                Hello Glen
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
