In Shark FX (also happens sometimes in CU sp4), when you try to dimension an object with more than one decimal place and the dimension is a whole number, you cannot get the dimension to show up as more than one decimal place. For example, 10 mm should show as 10.00 if I select 2 decimal places with trailing zeros, but it always shows up as 10.0 in Shark FX. Is this a bug?
Alexander Lau
a N d studio
Singapore
Alexander attached the following image(s):
(131kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Alexander, Ryan fixed today...
Great news, Tim. Thanks for the quick response. When can we expect to get the patch? Best regards Alexander Lau a N d studio
