Question on Expression Parser VIACad V6 Build 784 (#1784)
                The description of the expression parser indicates a value  can be a param .  Further, a param  is defined as an alpha  with an optional integer  (e.g. A, b2, etc.).  param  might offer a way to access data from an existing object (length, diameter, etc.).  As far as I can see, not so.  param  in an expression,  I can't figure out what param  really evaluates to.  If, for instance, you enter A1 in a data entry field, V6 returns an error message.
                >>way to access data from an existing object (length, diameter, etc.).   param  really evaluates to.
                Tim,
                Tim,
                Yes.  Once you define a constant, it will be remebered as it is stored in an ini file for later launches.
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
