(File Size) Has anybody ever managed to... (#3235)
                 save an SFX file that's about 12 GB? On a Mac, with a 32-bit ACIS engine?
And the file isn't finished yet. After more than 3 hours of saving and the file size approaching 12 GB I decided to pull the plug (i.e. force-quit), because I can't imagine I would be able to do anything with this monster.
FYI, the file is the result of an import (711 MB Pro/E assembly). Are such file sizes "normal" in any way? Or have I been stuck in an infinite loop of creating fractal geometries?
Bernd
bmeissner attached the following image(s):
(80kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Bernd >>save an SFX file that's about 12 GB? On a Mac,  >>with a 32-bit ACIS engine? I would suspect you would run out of memory.  32 bits will only access about 3.2 GB from our testing.   Is this using the v7 Sp1 beta? Tim
    Tim Olson  IMSI Design/Encore
                Originally Posted by: Tim Olson  I would suspect you would run out of memory.  32 bits will only access about 3.2 GB from our testing.
That's what I would have expected. And why I decided to force-quit.
Originally Posted by: Tim Olson  Is this using the v7 Sp1 beta?
I's 7.0 (929), the version I installed after v7 was released for the first time. I don't have a download link to the SP1 beta.
Bernd
                I sent you links to the Shark FX v7 Sp1 beta. Under Preferences:Filing there is a new option to save as V7 Sp1 format.  Try enabling that and saving the file.  The savings is related to how much acis data is in the file. You're pro/e import may have a good savings. Tim
                Originally Posted by: Tim Olson  I sent you links to the Shark FX v7 Sp1 beta.
Thanks, Tim, I'll give it a try and let you know what happens. Binary fractals instead of ASCII fractals, I guess ;)
Bernd
