#1 Posted : Thursday, August 18, 2011 7:50:21 AM(UTC)
Was thanked: 173 time(s) in 105 post(s)
Open a 2 D drawing (model to sheet).
Select a view.
Type "shift-arrow" (as if you think of nudging the view)...
---> all views get empty
---> Impossible to undo !
Don't forget to close the file WITHOUT saving....
#2 Posted : Thursday, August 18, 2011 2:49:11 PM(UTC)
Hi JL
Draw views are only visible when in the top view. Hitting Shift arrow will rotate the current view. Just hit the Top view and they contents of the draw view will be visible.
#3 Posted : Thursday, August 18, 2011 2:56:37 PM(UTC)
actually, it seems that you are turning the view, that make looks that the lines get vanished, l select top view and you will see all your draw again.
Luis G.
MacOSX Sonoma 14.7.1
#4 Posted : Friday, August 19, 2011 3:24:55 AM(UTC)
Thanks Tim,
Thanks Luis,
I just discovered a way to rotate... I'm still learning...
#5 Posted : Friday, August 19, 2011 9:33:41 AM(UTC)
Ditto
I forgot about it and when I hit Shift Arrow said UGH! Took me a few minutes to realize the view changed:)
