Thanks: 224 times Was thanked: 171 time(s) in 103 post(s)
This is an extremely old bug still on :
it is impossible to skin a small circle and a small ellipse.
See attached files
Bug skin.sfx
(36kb) downloaded 5 time(s). jlm attached the following image(s):
(46kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Cover surface closes the profiles, skin lofts between them. What's the issue?
Bug Confirmed. However, if you scale it by 10, skin solid and skin surface work. Something to do with the scale. You can always scale down for quick fix although it needs fixing.
>...small... means circle : 0,2mm ellipse : 0,7/0,4mm
>>it is impossible to skin a small circle and a small ellipse. Fixed in next builds. Tim
Originally Posted by: Tim Olson >>it is impossible to skin a small circle and a small ellipse. Fixed in next builds. Tim
It is now working fine.
Thans Tim.
Minor detail : the edge doesn't display correctly, even with highest resolution.
See picture (yellow curve is supposed to be the solid edge...
(128kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
