Simple file, too many bugs crowling... (#3072)
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
Here's a small file with a simple profile (exported "selected only" from a larger file.
All the bugs listed below have been mentioned at least once on this forum.
-1 The small preview icon does not reflect what is actually in the file. It shows something that was not exported.
-2 Gosh! 60 empty layers that I didn't want to export. Trash, Trash...
-3 Try to lathe the profile around the green line. A dialog says "Curves not planar", which is wrong - They are!
-4 See that there is a small gap in the profile. Too small ! The trim corner tool doesn't work on small gaps..
-5 Bloody hell, once again I opened the exported file without closing the original one. When I closed it, I lost all the menus, all the tools, and my unsaved work.
I think I should have posted that on the Beta section...
JL
 Bug trim.sfx
(15kb) downloaded 0  time(s). jlm attached the following image(s):
(52kb) downloaded 0  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: jlm  Hi, Here's a small file with a simple profile (exported "selected only" from a larger file. All the bugs listed below have been mentioned at least once on this forum. -1 The small preview icon does not reflect what is actually in the file. It shows something that was not exported. -2 Gosh! 60 empty layers that I didn't want to export. Trash, Trash... -3 Try to lathe the profile around the green line. A dialog says "Curves not planar", which is wrong - They are! -4 See that there is a small gap in the profile. Too small ! The trim corner tool doesn't work on small gaps.. -5 Bloody hell, once again I opened the exported file without closing the original one. When I closed it, I lost all the menus, all the tools, and my unsaved work. I think I should have posted that on the Beta section... JL
Hi jlm.
1/ Agreed that it doesn't seem to show what appears when loaded. Is it something from one of the other layers?
2/ Have you tried the Compact... option, under Menu->Edit?
3/  That message is a bit obscure, but it does Lathe OK once you've filled the gap in the profile.
4/  That's true, it repeated for me too. You could use the Apparent Intersection Snap, for now.
5/ I couldn't try that as I'm only running the Demo version.
Martin.
