Things missing since upgrade to 853? (#3360)
                A couple of things seem to have failed since installing the upgrade to build 853! I used to be able to flip the work plane with a hot key! Sadly I seem to have forgotten the key sequence. Or it just doesn't work any more. :confused: Neither can I find the documentation or tutorial which gave me the clue to this handy feature. Could somebody post a sticky in tutorials or add the keys to the reference card. I can no longer do any cross hatching! When I select 'Cross Hatch...' from the 'Pen' menu the dialog box title is: 'Definition file xhatch.ini not found' and the dialog is empty. Does anybody know where is and what should be in xhatch.ini TIA
                Originally Posted by: bradcan  A couple of things seem to have failed since installing the upgrade to build 853! I used to be able to flip the work plane with a hot key! Sadly I seem to have forgotten the key sequence. Or it just doesn't work any more. :confused: Neither can I find the documentation or tutorial which gave me the clue to this handy feature. Could somebody post a sticky in tutorials or add the keys to the reference card. I can no longer do any cross hatching! When I select 'Cross Hatch...' from the 'Pen' menu the dialog box title is: 'Definition file xhatch.ini not found' and the dialog is empty. Does anybody know where is and what should be in xhatch.ini TIA
Hi Brad
The key that flips the workplane is the c key after you click at a snap point like endpoint etc. tapping  the c key cycles the workplane.
(22kb) downloaded 0  time(s). You cannot  view/download attachments. Try to login or register.
                Thanks Jason, work plane flip still works. :) It must be the onset of senile decay. :eek:
