Thanks: 230 times Was thanked: 182 time(s) in 110 post(s)
Another one on the attached file :
- Simply skin the circle with the ellipse.
----> Bug #1 : the solid is transparent.
----> Bug #2 : "Check object" find it OK and it's obviously NOT.
----> Bug #3 : Boolean add with the other element (extrude) and it disappears
----> Bug #4 : Undo, Stitch the 2 solids together & trim with the arc... get a funny unclosed solid.
There is a workaround : build everything with surface tools before stitching.
---> it proves that the skin solid tool has still got a good potential to be improved !
Skin solid bug.sfx
(23kb) downloaded 5 time(s). jlm attached the following image(s):
(11kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
