Mirror tool lack of control (#363)
                I use this tool a hundred times a day, for geometry, surfaces, solids (mostly with option key down).
                JL
                It still would be appreciated..
                It would be nice to specify at least the first point pick thru the keyboard such as 50,0 or x50y0 and then have the choice to use smart cursor to finish up or another keyboard entry...This would be faster than using Con. Lines.
                A line should be an input also .. seems like a very reasonable request !
                Originally Posted by: jol  A line should be an input also .. seems like a very reasonable request !
You can already pick a line Jol ?
                You can pick two points on  a line, but you can't pick the  line.
    Shark FX 9 build 1143
OS X 9.5
matter.cc
                Originally Posted by: jlm  Is it possible ?
Hi JL
We've added a new tool for mirroring in Shark FX V6 called Linked Mirror.  It lets you do associative mirrors.  It's associative to the objects and an Infinite Plane.  I did a plane instead of a line as I need a plane to completely define a repeatable 3D mirror operation.
                Originally Posted by: Tim Olson  Hi JL
Great tool !
First step to symmetry...
Thanks Tim
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
