Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Hi, IGS export is working better than ever : CU solids and surfaces are usually perfectly received by our customers / suppliers. Though there are a few bugs with geometry. Bug #1 : on attached file - Select all and export IGS, - New file and import the same, ---> You see correct surface and solid, and reduced geometry far away from correct place. ---> It is obviously a reduction factor of 25,4 applied to geometry only (Inches strike again !) Bug #2 : on same file - Select solids and surface only and export IGS, with "selected only", - New file and import the same, ---> The unwanted geometry is still here (small & far away)... Regards, JL (Sorry, I forgot that Punch forum is the only place where I cannot upload anything with a Freebox modem - I'll send it by mail).
jlm wrote: (Sorry, I forgot that Punch forum is the only place where I cannot upload anything with a Freebox modem).
cannot imagine that the forum software is capable to detect or interested in knowing the used internet access hardware of a user.. more likely a configured limitation in the area of file format (extension) or file size.
Norbert
posh.de wrote: cannot imagine that the forum software is capable to detect or interested in knowing the used internet access hardware of a user.
Norbert,
I know it's strange, but when I remove the freebox and plug an older modem, the same file is uploaded quick & fast.
This is what I'm doing right now to attach the files.
I never met this issue on other forums.
Regards,
JL
Bug IGS.cu.zip
(77kb) downloaded 5 time(s). Bug IGS.igs.zip
(26kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
jlm wrote: I know it's strange...
spooky, has maybe something to do with the web server Punch! is using in connection with the NAT/port forwarding/open ports etc. of your modem/router...
anyway, get a Lancom or Zyxel or Draytek if you wanna have a working network hardware (OT).
Norbert
