Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Arcs have only one end point visible (+ center). Is there a reason for that ? I'd like to see both end points. JL
I can see both JL .. what are the circumstances ?
My post was lacking precision : Actually, I was trying to modify an old CU file (created in Nov 2004 with the latest CU version available at that time) and I realized that all the arcs were behaving in a very strange way. I reported the following arc bugs to Todd yesterday : - Only one endpoint showing - Start angle always "0" in info dialog, even when it's not. - Impossible to change the angles values (goes anywhere) - Impossible to corner trim (either cuts too far, or disappears) There must have been a mistake in one of the file format upgrade. Todd could confirm these points and I'm sure he will fix with the help of Tim. JL
Here's the file:
(a file created less than 3 years ago should'nt get corrupted just by software upgrade:( )
Corner trim bug.cu
(8kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
jlm wrote: Arcs have only one end point visible (+ center). Is there a reason for that ? I'd like to see both end points. JL
We support a variety of arc definitions. This arc is defined as a center, starting point, and angle. When we do a show points, we only show the points needed for the specific definition. Various arc defintions include:
--center, start point, angle
--three points on
--start, end, middle
--center, start point, end point
etc
jlm wrote: - Only one endpoint showing - Start angle always "0" in info dialog, even when it's not. - Impossible to change the angles values (goes anywhere) - Impossible to corner trim (either cuts too far, or disappears) JL
Thanks Tim,
Point#1 : OK, I understand your answer.
--> Don't you think the info dialog should tell the type of arc ?
point#2 : then, "0" means "relative start" and not absolute angle for this type of arc.
--> Isn't it confusing ?
Points #3 & 4 are still looking buggy.
JL
