nov4vc47
#1 Posted : Monday, December 31, 2012 3:28:12 AM(UTC)
nov4vc47
I use ViaCad V7.
I still wonder why the display of an object while rotating/turning (by Click$Drag of the wheelbutton of the mouse) the display of the object temporarely changes from "Display with shade" to "Display hidden lines" (only the visible lines).
Stopping the rotating/turning, it takes 1-2 seconds, and the display object will return to the "Display with shade".
This is also the case using the 3DConnexion-device.
I thought that this choice was made in the program to reduce computing time, so I did not bother.
But is it normal?
#2 Posted : Monday, December 31, 2012 2:53:38 PM(UTC)
You can change the display preferences by double click on display style icon or view/shade options menu
MacOSX Sonoma 14.7.1
nov4vc47
#3 Posted : Tuesday, January 1, 2013 4:42:08 AM(UTC)
nov4vc47
Thanks for the rapid reaction on the edge of the new year.
By double clicking on the dispay-icon, I could chose the right option.
Now it works fine.
Again thanks.
