Alexander
#1 Posted : Friday, June 26, 2009 2:15:28 AM(UTC)
Alexander
Hi Tim
I am trying to do a simple animation movie of walk around (fly by) an object that I have designed.
I drew an eliptical path around the object, select the fly by icon, slect the path and select a point on the object. I click OK for the ensuing menus to save the movie. A preview window pops up and shows some images of the movie being rendered. But at the end of it, the movie file is no where to be found. It is completely NOT saved.
Please advise. Thanks.
Alex
Macbook Pro, OS10.5, Shark FX 750
#2 Posted : Friday, June 26, 2009 3:18:59 AM(UTC)
Hi Alexander
Just tried it here .. (Mac) .. and no problem
Can somebody else please try it on a PC
.. See if we can work out the problem
Alexander
#3 Posted : Sunday, June 28, 2009 9:00:58 PM(UTC)
Alexander
Hi Jol
Thanks for trying. I tried it with several different files but still can't get the Fly-By Animation to save. I can only save a clip using Object VR.
Best regards
Alex
#4 Posted : Monday, June 29, 2009 2:34:39 AM(UTC)
Come on guys - can we please have somebody with a PC check this function for Alexander !!
It appears to work fine on the mac
In the meantime Alexander - can you try it just with a cube .. perhaps then we can see if it's related to your geometry
L. Banasky
#5 Posted : Monday, June 29, 2009 2:51:09 AM(UTC)
L. Banasky
Was thanked: 157 time(s) in 107 post(s)
Hi Jol,
Alex's signature indicates that the Mac is being used.
#6 Posted : Monday, June 29, 2009 2:54:48 AM(UTC)
Bugger - thanks Larry !
OK - can you get a build later than 750 ?
Alexander
#7 Posted : Thursday, July 2, 2009 12:51:41 AM(UTC)
Alexander
Hi Guys
Thanks for trying.
I tried again today, and I found that if I saved the file on the Desktop, instead of a specific work folder, the animation saves! So maybe it is something to do with Shark on Mac. My folder is not locked (I've checked).
By the way, how do I get any Shark builds higher than 750? When I check for the latest version, it always tells me that I already have the latest in 750.
Thanks again.
Best regards
Alex
Steve.M
#8 Posted : Thursday, July 2, 2009 3:20:43 AM(UTC)
Steve.M
Hi Alex,
The latest build is 838:- http://forum.punchcad.com/showthread.php?t=2423
- Steve
